I had no idea you could limit the speed with the ibus. Where did you find these codes?
Printable View
The speed limit codes are for the factory navigation unit if I remember right. It sets a beeper after a certain speed. Don't worry it won't apply your brakes on the highway until you're down to 50kmh :)
Sorry to thread jack (It is kinda relevant o your skin tho :) ), but WaRFiElD you ibusRR is based on the original ibus comm that supports both keyboard & RR commands, i see in your version keyboard is removed from the ini. I have got the phone button to send a key command instead of sending a RR command
This is the comparison I mean
IbusRR ini=
IbusCOMM.iniCode:;Steering Wheel PHONE Press
[ID:STW_PHONE_PRES]
MsgTemplate="5004C83B8027"
KeyboardMap="MUTE"
Your version will still work after hibernation as the ibuscomm version has to be restarted after hibernate otherwise it doesnt work. If i replace the ini is it still compatible?Code:[ID:STW_PHONE_PRES]
Label="S.Wheel PHONE Press"
Parse=True
KeyboardMap="{F2}"
;RRCommand=""
I use iGuidance and was thinking of using this skin. However, when I start up the GPS, it doesn't launch the App. Other skins work fine. Any ideas why? Thanks.
@dan32500: is it possible to release the iList version of your skin? I'm working on a new version of iBusRR with scroll support from the steering wheel on the audio player/browser skin and I'd like to see if it works well on an iList.
thank you!
@jonessc: The current version of iBusRR only support sending COM commands to RR. However, if RR supports sending keystrokes (which I don't know) you could probably bind a command to a keystroke in ExecTBL.ini
Open skin's ExecTBL.ini and comment out the "GPS" line. (add a slash '/' in front).
UPDATE:
I released a more complete version with OBC and SETTINGS screens done... see first post for download link.
@WaRFiElD: IbusRR stoppend workin for some time in my car.. need to check, could be the cable connection.
