Page 3 of 13 FirstFirst 123456789101112 ... LastLast
Results 21 to 30 of 129
Thread: [REL] iGoBMW transparent
  1. #21
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    I had no idea you could limit the speed with the ibus. Where did you find these codes?
  2. #22
    Aug 2005
    Canada
    The speed limit codes are for the factory navigation unit if I remember right. It sets a beeper after a certain speed. Don't worry it won't apply your brakes on the highway until you're down to 50kmh
  3. #23
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by WaRFiElD View Post
    Sorry to thread jack (It is kinda relevant o your skin tho ), but WaRFiElD you ibusRR is based on the original ibus comm that supports both keyboard & RR commands, i see in your version keyboard is removed from the ini. I have got the phone button to send a key command instead of sending a RR command
    This is the comparison I mean
    IbusRR ini=
    Code:
    ;Steering Wheel PHONE Press
    [ID:STW_PHONE_PRES]
    MsgTemplate="5004C83B8027"
    KeyboardMap="MUTE"
    IbusCOMM.ini
    Code:
    [ID:STW_PHONE_PRES]
    Label="S.Wheel PHONE Press"
    Parse=True
    KeyboardMap="{F2}"
    ;RRCommand=""
    Your version will still work after hibernation as the ibuscomm version has to be restarted after hibernate otherwise it doesnt work. If i replace the ini is it still compatible?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  4. #24
    Feb 2008
    Ireland
    Is there a way you could add a transparent visualisation (low opacity) on the menu skin that would replace the background?
    I don't think so, I know I can have a trasparent vis but that will be on top of all layers not under like a background.
  5. #25
    I use iGuidance and was thinking of using this skin. However, when I start up the GPS, it doesn't launch the App. Other skins work fine. Any ideas why? Thanks.
  6. #26
    Aug 2005
    Canada
    @dan32500: is it possible to release the iList version of your skin? I'm working on a new version of iBusRR with scroll support from the steering wheel on the audio player/browser skin and I'd like to see if it works well on an iList.
    thank you!
  7. #27
    Aug 2005
    Canada
    @jonessc: The current version of iBusRR only support sending COM commands to RR. However, if RR supports sending keystrokes (which I don't know) you could probably bind a command to a keystroke in ExecTBL.ini
  8. #28
    Feb 2008
    Ireland
    Quote Originally Posted by Fmstrat View Post
    Open skin's ExecTBL.ini and comment out the "GPS" line. (add a slash '/' in front).
    UPDATE:
    I released a more complete version with OBC and SETTINGS screens done... see first post for download link.
    @WaRFiElD: IbusRR stoppend workin for some time in my car.. need to check, could be the cable connection.
  9. #29
    Nov 2006
    Wales, UK
    the v1.89 ibus comm i have sourse for supports both keyboard and rr commands, pm if you want a copy
    CarPuter Progress:
  10. #30
    Feb 2008
    Ireland
    Quote Originally Posted by jonessc View Post
    Tried that one aswell but I dont think u can send Ibus commands with it like u can with IbusRR - can only read Ibus commands.
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 12:23 PM
  2. Replies: 5
    Last Post: 01-06-2008, 09:36 PM
  3. transparent tutorial?
    By davidp in forum RR Skins
    Last Post: 08-28-2007, 09:24 PM
  4. Winamp transparent visualization issues
    By TSur in forum Road Runner
    Last Post: 06-12-2007, 05:54 PM
  5. Transparent skins possible???
    By Supergong in forum FreeDrive
    Last Post: 01-13-2006, 02:25 PM
