E46 IBUS codes
All codes tested on a E46 318ti
00 05 BF 7d 00 30 f7 - sun roof öffnen and if necessary unlock
00 05 BF 7d 00 20 chk - sun roof öffnen and lock
00 05 BF 7d 00 70 BF - sun roof close and if necessary unlock
00 05 BF 7d 00 60 chk - sun roof close and lock
00 05 BF 7d 00 00 chk - sun roof lock
00 05 BF 7d 00 10 chk - sun roof unlock
3f 05 00 0c 7e 01 chk - sun roof a piece open
3f 05 00 0c 7f 01 chk - sun roof a piece close
3f 05 00 0c 52 01 chk -
windows in front driver's side a piece open
3f 05 00 0c 53 01 chk - windows driver's side a piece close in front
3f 05 00 0c 54 01 chk - windows in front front seat passenger side a piece open
3f 05 00 0c 55 01 chk - windows front seat passenger side a piece close in front
3f 05 00 0c 41 01 chk - windows in the back driver's side a piece open
3f 05 00 0c 42 01 chk - windows in the back driver's side a piece schlissen
3f 05 00 0c 44 01 chk - windows in the back front seat passenger side a piece open
3f 05 00 0c 43 01 chk - windows in the back front seat passenger side a piece schlissen
80 04 BF 11 00 2a - Innenraumbel. abdimmen
3f 05 00 0c 01 01 chk - Innenraumbel. switch off
3f 05 00 0c 30 01 chk -??? + Innenraumbel. abdimmen
3f 05 00 0c 60 01 chk - Innenraumbel. für 3 sec. turn on (no Fade)
3f 05 00 0c 68 01 chk - Innenraumbel. out and again andimmen
3f 05 00 0c 03 01 chk - doors unlock (pressed like Knopf@Innenraum)
3f 05 00 0c 34 01 chk - doors lock (pressed as with key)
3f 05 00 0c 46 01 chk - doors + gas cap hard LOCK, trunk openly
3f 05 00 0c 47 01 chk - driver's door lock (door handle lässt itself heavily pull)
3f 05 00 0c 4f 01 chk - all doors except driver's door verschlssen
3f 05 00 0c 97 01 chk - doors lock (hard LOCK)
3f 05 00 0c 02 01 chk - trunk open
3f 05 00 0c 05 01 chk - trunk open (again)
3f 05 00 0c 95 01 chk - trunk open (again)
3f 05 00 0c of 49 01 chk - windshield wipers in front
3f 05 00 0c 62 01 chk - disk wiping water in front spray
00 04 BF 76 0x chk - flashing: 2 = warnblinker, 4 = headlight low beam, 8 = high beam
3f 05 00 0c 70 01 chk - warnblinker (IKE + LCM) + Innenraumbel. andimmen
3f 05 00 0c of 75 01 chk - warnblinker (LCM) für 3 seconds
3f 0b BF 0c 00 00 00 00 00 00 of 01 06 chk - fog headlights
3f 0b BF 0c 00 00 00 00 00 40 00 06 chk - taillight left (+A)
3f 0b BF 0c 00 00 00 00 00 00 08 0c chk - taillight right (+A)
3f 0b BF 0c 00 00 00 00 01 00 00 06 chk - stop light above
3f 0b BF 0c 00 00 00 00 08 00 00 06 chk - stop light left (+A)
3f 0b BF 0c 00 00 00 00 10 00 00 06 chk - stop light right (+A)
3f 0b BF 0c 00 00 00 00 00 02 00 06 chk - headlight low beam in front right
3f 0b BF 0c 00 00 00 00 00 04 00 06 chk - headlight low beam in front left
3f 0b BF 0c 10 00 00 00 00 00 00 06 chk - headlight low beam in front + in the back retards
3f 0b BF 0c 00 00 00 00 00 10 00 06 chk - high beam left + headlight low beam reciprocally
3f 0b BF 0c 00 00 00 00 00 20 00 06 chk - high beam right + headlight low beam reciprocally
3f 0b BF 0c 00 00 80 00 00 00 00 06 chk - headlight low beam + with Ignition high beam (IKE+LCM)
3f 0b BF 0c 00 00 00 00 00 00 20 06 chk - turn signal shines at the rear left durably (+A)
3f 0b BF 0c 00 00 00 00 00 00 80 06 chk - turn signal in the back right shines durably (+A)
3f 0b BF 0c 00 00 00 00 20 00 00 06 chk - turn signal in front left shines durably (+A)
3f 0b BF 0c 00 00 00 00 40 00 00 06 chk - turn signal in front right shines durably (+A)
3f 0b BF 0c 00 00 00 40 00 00 00 06 chk - side marker light left
3f 0b BF 0c 00 00 00 80 00 00 00 06 chk - side marker light right
3f 0b BF 0c 20 00 00 00 00 00 00 of 06 chk - warnblinker
3b 05 80 41 0a 10 chk - average speed delete
BF 03 80 16 2a - requirement odometer reading
3b 06 80 40 09 00 xx chk - speed limits set (audio signal with exceeding)
3b 05 80 41 09 20 chk - speed limits on current speed set
3b 05 80 41 09 08 chk - deactivate adjusted speed limit
Received codes:
44 05 BF 74 04 xx chk - key xx put in
44 05 BF 74 00 FF chk - keys taken
00 04 BF 72 16 df - latch button pressed on remote maintenance
00 04 BF 72 26 ef - opening button pressed on remote maintenance
00 04 BF 72 06 cf - button on remote maintenance released
80 05 BF 18 xx yy chk - xx = Geschwindigkeit/2, yy = Drehzahl/100, message every 2 sec..
All codes of the sending address 3f are only few seconds active. Meant that for example the window not completely on, but only a piece goes far.
