Page 6 of 13 FirstFirst 12345678910111213 LastLast
Results 51 to 60 of 128
Thread: [REL] iGoBMW transparent
  1. #51
    Feb 2008
    Ireland
    Quote Originally Posted by Jaskari View Post
    I think PGUP and PGDOWN should be placed the other way around, but I guess it is a matter of opinion.
    Dan do you know the code for changing Fahrenheits to Celsius in OBC (like consumption unit is changed in SET_OBC_TO_L100Km)? I don't have OBC in my car and BMW skin shows fahrenheits instead of celsius in outside temp. Or is there a way in Roadrunner to take part of $OUTSIDETEMP$ (stripping + and C) and then doing a conversion (C=F-32x5/9)?
    Also one thing is bugging me.. after stopping the engine RPM meter wont go to 0. Is this normal?
    Oh yeah, I only changed the single press command, I have't noticed the hold command cose I didn't use it.
    I'm not sure of a code to change C/F and 12H/24H - I used the right knob on the cluster. Maybe warfield knows cose he gave me the code for L/100Km.
    You can try editing bmw.skin to convert F to C:
    L,610,271,167,19,240,240,240,14,"Arial:B","=OUTSID E: $OUTSIDETEMP$","CENTER"
    TO
    L,610,271,167,19,240,240,240,14,"Arial:B","=OUTSID E: $OUTSIDETEMP$","F2C"
    I think the RPM thing is cose of the pugin not updating the variable to 0 when doesn't find a value in IBUS.
  2. #52
    Jul 2006
    Finland
    Quote Originally Posted by dan32500 View Post
    TO
    Tried F2C instead of CENTER, but it didn't help. Maybe it wont work because $OUTSIDETEMP$ variable shows +54 C and not +54 F (RR thinks, that it is already fahrenheits). Gotta ask from Warfield if he can think of something..
    Maybe Warfield could add something to IBusRR for detecting when motor is not running and then reset RPM variable inside IBusRR and update RPM to RR..
  3. #53
    Apr 2007
    Nice Skin! The IBUS stuff is terrific. One question.... do you have a code to switch OBC back to MPG? (Edit: Disconnecting the battery works!) However a code would be a lot more elegant. Not to mention easier to do while driving
  4. #54
    Dec 2006
    Excellent BMW skin. iGo is now my main RR skin. One thing I couldn't figure out:
    I used to be able to use my Navi right knob to scroll through the menu items and pressing on the knob acted as [ENTER] with LSX, Simplistque, or FX skin. I couldn't do the same with iGoBMW. Any ideas or help is appreciated. Thx!
  5. #55
    Nov 2005
    i am only getting a vertical small (pink) bar with this skin where i can see half of the compass/speedo, although background path set. anything to do with flash - special version or player required?
  6. #56
    Jul 2006
    Finland
    Quote Originally Posted by upspace View Post
    I had the same problem... check your rr.ini file for fastmode line.. it should be "fastmode=-1".
  7. #57
    Nov 2005
    hhhm not for me. any other tips?
  8. #58
    Feb 2008
    Ireland
    Check again and make sure a valid background is set.
    You will need to update IbusRR.ini with your previous settings but in the new format.
    Sorry, I don't, will have to wait for WaRFiElD to come back.
  9. #59
    Feb 2007
    Hi, where can I download or buy iGo8 please?
    I use actually sygic but I always get problems with RR using any GPS software
  10. #60
    Newbie Asterix1965's Avatar
    Jan 2007
    Hello,
    Despite its adobe flasplayer installed in PCs used by car makes me not view the files *.swf menu Bmw.skin
    Also in the menu change background I do not see backgrounds
    Do you know how to solve the problem ?
    Tanks
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. Replies: 5
    Last Post: 01-06-2008, 10:36 PM
  3. transparent tutorial?
    By davidp in forum RR Skins
    Last Post: 08-28-2007, 10:24 PM
  4. Winamp transparent visualization issues
    By TSur in forum Road Runner
    Last Post: 06-12-2007, 06:54 PM
  5. Transparent skins possible???
    By Supergong in forum FreeDrive
    Last Post: 01-13-2006, 03:25 PM
