Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 81 to 90 of 128
Thread: [REL] iGoBMW transparent
  1. #81
    Feb 2008
    Hi,
    not sure, where/how?
  2. #82
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    Added: backgroundpath=C:\Program Files\Road Runner\backgrounds\
    (in addition to the standard background= that RRConfig sets)
    Registered GDIPlusWrapper.dll with RegSvr32
    Tried a PNG instead of a JPG.
    Still no good.
    -InfinitiPC
  3. #83
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Should be in the Road Runner Folder. If you don't have it, it is attached.
    Go to Start>>Run and type in
    regsvr32 "C:\Program Files\Road Runner\GdiPlusWrapper.dll" and hit enter.
    Attached Files Attached Files
  4. #84
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by InfinitiPC View Post
    Still no good.
    If a skin folder has a SKIN.ini file in it, it will override the RR.ini file.
    Look in the skin folder for the skin.ini file and change your background path there..
  5. #85
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Here is another hint. Run RRConfig.exe and select your backgrounpath there.
  6. #86
    Feb 2008
    Hi,
    Done all that in the editor, still all grey with just white boxes where the buttons are
  7. #87
    Feb 2008
    Ireland
    Quote Originally Posted by the_big_1 View Post
    Hi Dan,
    When I open the skin in the skin edito, it doesnt show the back ground image, any ideas?
    The skin editor uses its own background.jpg file. Replace that with one of the backgrounds of my skin if you want to see it.
    For NAV; I use Igo8 with a custom 800x544 skin.
    For mobile/phone screen; I haven't looked into yet as I don't see it working that well to be worth making.
    As an example:
    skin.ini should have:
    background=C:\Program Files\Road Runner\Backgrounds\Lines_red.jpg
    rr.ini should have:
  8. #88
    Feb 2008
    Hi,
    Do you have your background as a jpeg as all the ones in the zip are png.
    Cheers!
  9. #89
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Do you have the new Skin Editor ?
    If not here it is.
    http://myspotontheweb.no-ip.org/Down...ditor_v.71.zip
    As for a background, you can use any *.jpg file you want, in the format 800x600 and copy it in the skin Editor Folder.
    for your convenience, here is one. Right click annd save as, then save it in the skin editor folder.
  10. #90
    Mar 2008
    I figured it out. Had taken a screen-shot of RR + inifiles + bgdir, uploaded it to this post, then studied it one last time before posting... noticed the bgdir was named "backrounds" rather than "backgrounds". lol
    -InfinitiPC
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. Replies: 5
    Last Post: 01-06-2008, 10:36 PM
  3. transparent tutorial?
    By davidp in forum RR Skins
    Last Post: 08-28-2007, 10:24 PM
  4. Winamp transparent visualization issues
    By TSur in forum Road Runner
    Last Post: 06-12-2007, 06:54 PM
  5. Transparent skins possible???
    By Supergong in forum FreeDrive
    Last Post: 01-13-2006, 03:25 PM
