two small things that I've noticed ...
When the skin starts for the first time, if you don't have RR installed in c:\program files\.... then the background will not set ... even if you select one from the theme changer screen. This is because of hardcoded paths saved in the skin.ini as I later found out.
Those lines (exept the logopath) in the skin.ini file are obsolete as the skin reads the backgroundpath from rr.ini
Perhaps a load default's hidden button on the main menu ... or I could send you my script that checks for a valid background image on skinstart and if not found loads a predefined image from the skin folder ... !!
And on the exit menu, it's not clear which button will simple "Exit" the skin, as the skin options are hibernate, standby, restart, logoff, power off ?? I found out it was the "logoff" option, but maybe a name change on the button ?
oh .. and this line is in the skin.ini
notice the incorrect spelling for "OMEGA" .. you might want to see where that is coming from.
This line can be deleted as well. No function.
otherwise ... so far so good, really nice work.[/QUOTE]
Here are the 2 new exit menus with the EXIT Button, just copy and replace the old ones.![]()
LinkBack URL
About LinkBacks
