Page 5 of 23 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 223
Thread: OMEGA 1.0.1 Beta Release
  1. #41
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Minor Bug
    In audio_player2 the mute indicator "box" (as seen with SkinEditor) needs to be moved to cover the "MUTE" graphic.
    Also, the "MUTE" in audio_player1 seams out of place. (i believe somebody already mentioned it)
    I can't add any more great compliments for this skin that have not already been said.
    Thanks for sharing.
  2. #42
    Mar 2007
    I found a little bitty bug. When I'm in the PSU system info, the "Go Back" button in the lower right displays the exit menu button image.
    could you tell us, in a more detailed way, how to change the date to the track info? because for some reason, (today is 07/20/2008) mine displays the date as 07/08/2020 LOL!
  3. #43
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by treetop777 View Post
    Thanks for sharing.
    For now, goto thread 28 and 31 and update your files.
    Thanks for your kind words.
    MGD
  4. #44
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by mshale View Post
    I will update the graphics on Monday and reupload the fixed version.
    If you want to change the labels from Date to Track Name, find the label date and change the code to..
    "TRACKARTIST||= - ||TRACKTITLE"
  5. #45
    Mar 2007
    This is some great work MGD, I'm really enjoying testing the skin. Does the skin automatically change from the day to the night version of the skin? Or do I need to make a copy of the Omega folder and call it Omega day and set the theme in the skin and have road runner switch the skin that way?
    Thanks again Manny
  6. #46
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    It will change the gamma from day to night. We don't have a way of changing the background by times yet.
    Like a command "OnGamma" do something.
    Hope Guino can figure it out.
  7. #47
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by MGD View Post
    There is, however, a release plugin that execute commands based on time.
    guino's timeexec plugin
    Simple enough to implement.
    GL.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  8. #48
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Thanks Sal, that is what I tryed with code and it worked but this is mucho easy.
    Thanks Pro
  9. #49
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by Sal R. View Post
    GL.
    yep i agree with you sal , i have been using this plugin for my BG changer and it dose work as intended, but with limits, rr has to be running for changes to take effect, if you run rr after the times in the ini rr will not change, so a script maybe in order for that bit, which i have not done myself as yet as i am going down another avenue with it.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #50
    x10
    x10 is offline
    Constant Bitrate x10's Avatar
    Mar 2004
    Pittsburgh, PA
    something small that I noticed.....your weather maps only view the southwest region of the US....I can't seem to find a way to change this....even if you made it so that you could view the entire US instead of just SW US that would be more handy for us East Coasters....
  1. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  2. How can I be a part of the beta group?
    By RedGTiVR6 in forum StreetDeck Bluetooth
    Last Post: 01-08-2008, 10:03 AM
  3. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  4. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  5. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
