Page 6 of 23 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 223
Thread: OMEGA 1.0.1 Beta Release
  1. #51
    Jul 2008
    great thanks
  2. #52
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by x10 View Post
    something small that I noticed.....your weather maps only view the southwest region of the US....I can't seem to find a way to change this....even if you made it so that you could view the entire US instead of just SW US that would be more handy for us East Coasters....
    Extract this file and overwrite the one in the Scripts folder.
    Rename the file to RADAR.exe
    Attached Files Attached Files
  3. #53
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Update
    New Version available in first port. Made some minor changes.
  4. #54
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    is there any way to get a copy of the psd's?, i need to create some extra screen for my own personal use.
  5. #55
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    With the latest release, the backgrounds don't work correctly. Before, it read from the BG folder within Omega but now, it seams to conflict the the BG path in rr.ini. I have rr.ini (picturepath and BG path) pointed to a folder in "my pictures" and unless BOTH folders have the same exact picture, in won't show in Omaga's BG chooser.
    I copied the skin.ini from the first release of Omega into this latest release and it now reads again from Omega's BG folder only.
    Ideally, it would read from rr.ini's BG path. (for the benefit of us skin junkies)
    No biggy, it can be fixed.
  6. #56
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    This skin is so F***ing awesome!!! Thanks Manny. The YouTube screen just rules. I can now easily and instantly play any music video ever made (and even save it if I want). Incredible!
    -InfinitiPC
  7. #57
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Glad you like it, but don't thank me for it as it was done by ElCamino, all credit goes to him for this Plugin. I actually don't use it in my skin, instead I use the tire pressure monitor.
    Actually, I just checked the skin and there are the up and down buttons missing. Download the new skin file rename it to YouTube.skin and copy it over the old one.
  8. #58
    Apr 2008
    mgd i cant get this skin of yours to work either
    when it loads the only thing i get is a blue bar 15mm wide running top to bottom of my screen
    i did load once but was offset change resolution on car pc to match skin resolution 800x600
    and no luck
    since done a full reinstall off xp and rr still the same feel like kicking the crap outta the car pc
  9. #59
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Did you register GDIPlusWrapper.dll ?
    In RR.ini
    Fastmode=-1
  10. #60
    Apr 2008
    ok i finally got it to load only at a resolution of 640 x 480 any higher causes the graphics driver to default to vga mode
    also having lots of problems with the radio and gps
    the silabs radio starts muted and i have to change to a different frequency and then back agin for it to lock the frequency
    and with the gps i use idrive
    if i set an external gps in rr with this skin it doesnt load no matter what i try
    so sadly atm i have to stick with my old skin
  1. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  2. How can I be a part of the beta group?
    By RedGTiVR6 in forum StreetDeck Bluetooth
    Last Post: 01-08-2008, 10:03 AM
  3. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  4. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  5. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
