Page 7 of 23 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 223
Thread: OMEGA 1.0.1 Beta Release
  1. #61
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    I think I found a bug. When I doubleclick a background in the Theme Select screen, it loads it as a playlist and cycles through the pictures using Winamp, and the list jumps around (since winamp is on shuffle).
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  2. #62
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by hollow View Post
    ok i finally got it to load only at a resolution of 640 x 480 any higher causes the graphics driver to default to vga mode
    This is aproblem with your graphic driver not the skin.
    also having lots of problems with the radio and gps
    the silabs radio starts muted and i have to change to a different frequency and then back agin for it to lock the frequency
    The skin does not give any commands to the audio line you using for the radio. Check your settings in RR.ini for that.
    and with the gps i use idrive
    if i set an external gps in rr with this skin it doesnt load no matter what i try
    Look in the EXECTBL.ini from the skin and comment out any line that has to do with iGuidance. Then call you iDrive with "GPS"
    so sadly atm i have to stick with my old skin
    Now you have alot of reading to do.
  3. #63
    Apr 2008
    hahaha one good thing come out of it ,my mate was messing and locked the pc then tried to unlock it ,boy that siren was loud as hell ,he poked himself in the eye ,i couldnt stop laughing ,and coldnt turn off the pc to shut it up i was laughing that much
  4. #64
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    The acces code is 1234, don't give it away.
  5. #65
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    RR Media Plugin
    Even I have'nt Beta tested it, but I think I will be ready for it. Still workin on the 15+ menus.
  6. #66
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    there is an "issue" with your screen lock ...
    when you call the "system_lcok.skin" and select "YES" to load the "system_locked.skin" you can still press "ESC" even on the "system_locked skin to cancel back through the skins ... even tho the displayed skin says the system is locked ...
    the system only becomes fully locked after you click the "unlock" button to call the locker program ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  7. #67
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Look in your KeyTbl.ini file and remove the code from key 27.
    27,""
  8. #68
    Low Bitrate InfinitiPC's Avatar
    Mar 2008
    Infiniti logo for this skin attached.
    -InfinitiPC
  9. #69
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Thank you for the Logo.
    It is kind of hard to read with the chrome letters. So, I modyfied it a little so that it is better to read.
  10. #70
  1. Replies: 116
    Last Post: 08-07-2008, 11:23 AM
  2. How can I be a part of the beta group?
    By RedGTiVR6 in forum StreetDeck Bluetooth
    Last Post: 01-08-2008, 10:03 AM
  3. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  4. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  5. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
