Page 12 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 111 to 120 of 146
Thread: hAv1c+ v3.02 - the fastest and most stable RR skin - v4 coming very soon!
  1. #111
    Jun 2007
    Colorado
    Thanks, that did the trick. I'm on my home PC right now and I never bothered to install the fonts.
  2. #112
    Constant Bitrate aperali's Avatar
    Aug 2007
    Rio de Janeiro, Brazil
    Hi guys,
    Why Im getting those characteres in order to have symbols. Ive installed all required fonts!
    Very good skin so far, thank you!
  3. #113
  4. #114
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    What he said..or..you dont have the correct "carpc.ttf" font installed - there are two variations. Look in the MAV1C skin tread.
  5. #115
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    The correct version should have been included with the recent version. It is in the skin folder. Just copy it into your c:\Windows\Fonts folder and it should install it. You'll also need to install the bgothm font, so that the text looks like the screen shots in the first post. If you don't have the fonts, they can be downloaded seperately here:
    JC Auto Design's CarPC.ttf
    Bank Gothic Medium - bgothm.ttf
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  6. #116
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by monkeyracer View Post
    The correct version should have been included with the recent version. It is in the skin folder. [HL]Just copy it into your c:\Windows\Fonts folder and it should install it. [/HL]You'll also need to install the bgothm font, so that the text looks like the screen shots in the first post. If you don't have the fonts, they can be downloaded seperately here:
    I would recommend using the Control Panel --> Fonts --> Install fonts rather than just copy and pasting them into the folder.
  7. #117
    Aug 2007
    Thanks guys,
    I did that. I downloaded these fonts, installed their from CP\fonts but I still have problems. see below.
  8. #118
    May 2007
    Lakehood, CO
    Ok, both of my fonts seem to be working, the other font needed is webdings available here:
    Webdings
    I thought that was a standard windows font, or apparently included in Internet Explorer.
    That should fix the problem.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #119
    Aug 2007
    Webdings
    Thanks for helping me.
    Youre right! I accidentaly deleted this fonts during installation of webdings 3.
    But still have no success. I reinstalled all fonts many times, reinstalled the hAv1c+ v3.02 skin but still have the same characters as my last post. Tryied to edit the mainmenu.skin to match same fonts names, but nothing seems to change!
    EDIT: Aha!! under the gps menu I got this!?!?!?
    EDIT1: But, it seems to be an image png file :-(
  10. #120
    May 2007
    Lakehood, CO
    For the fonts, what OS are you running?
    There are only three fonts used in this skin:
    bgothm.ttf
    CarPC.ttf (by JC Auto Design)
    webdings.ttf
    Mainmenu.skin is just for the main menu pop up when you click the menu button in the top left corner. Each and EVERY skin file would need to be updated if you wanted to do it that way. I'd recommend opening the skin in skineditor and double click on the label L102 (on the left column in skineditor) and next to the font name, press the ellipsis (the ... symbol) to open the font dialog, and select Webdings (not Webdings 2 or 3) and then click OK. If webdings isn't in the list, you will need to try to re-install it. If it is in the list, then everything should work as is...
    The gps screen is a .png since the Overlay Plugin doesn't like to play well with labels.
    It's designed to work with iGuidance, but other GPS programs can be used (Garmin Mobile PC, for one) with little or no editing.
    Hope this helps.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
