Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 146
Thread: hAv1c+ v3.02 - the fastest and most stable RR skin - v4 coming very soon!
  1. #31
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by monkeyracer View Post
    v2.1 posted on first post. gas prices won't work until the plug in is released.
    That'll be later tonight
  2. #32
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Thanks for the plug-in E. It's been working great so far.
    I forgot to post about how to use the new rrgas plugin:
    After the screen is loaded, there are some options on the right set of buttons.
    -Pressing ZIP button will bring up the NUMOSK and allow you to type in your zip code.
    -Pressing the Within button will bring up the numosk and allow you to limit your search to a certain distance. If you press and hold this button, it will sort the results by the closest station.
    -Pressing any of the fuel grades will sort the list by that grade.
    In the very soon to be released update, if you press and hold each fuel grade, it will become your default, and every time you navigate to the rrgas skin it will sort the results by that fuel grade.
    -Pressing the info at the top (last update, sort method) will force a refresh if web connectivity is avaialable
    -Pressing each gas station will bring up iGuidance, clear any previous route, enter the coods of the station and provide directions to it. Soon will be more support for other nav programs, (freedrive already supported by E's personal version and the rrgas plugin.)
    Make sure you've already opened up IG before navigating to it, otherwise, for some reason, the GPS_OVERLAY doesn't work. Also, make sure you have the plugin in it's own folder in the RR folder (c:\...\Road Runner\RRGas\) for the paths to work correctly.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #33
    May 2007
    Lakehood, CO
    I also just noticed that the battery slider doesn't work at 100% charge, I did the calculations wrong. Open up exectbl.ini and replace these lines:
    Code:
    "ONSKINSTART","StrRepl;powermon_battpercent;%;;BATTERY||EVAL;BATT;$BATTERY$*656",menu.skin
    "TIMER","EVAL;BATT;$BATTERY$*656",menu.skin
    with these lines:
    Code:
    "ONSKINSTART","StrRepl;powermon_battpercent;%;;BATTERY||EVAL;BATT;$BATTERY$*655",menu.skin
    "TIMER","EVAL;BATT;$BATTERY$*655",menu.skin
    Basically at 100% the slider position was 65600, but the top of the slider is 65535, and RR won't display the solid slider if it's beyond the slider range.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  4. #34
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Same applies to FreeDrive, it has to be running in the skin already to receive the coords otherwise they get sent before it is loaded up.
  5. #35
    Jun 2007
    I'm pretty sure these problems are me not setting it up correctly...
    when I click "preview skin" for it in rrconfig, nothing shows up
    when I open the skin, it doesn't go full screen, and I can see a good bottom chunk of my windows background.
    that was pretty much it, it hung a couple of times, but I think that was from all the starting/stopping of RR, there was probably an unclean exit somewhere. Also, I need to update to the newest version of RR.
  6. #36
    May 2007
    Lakehood, CO
    I've never been able to get the preview day/preview night buttons to work for any skin.
    This skin is designed to be run at 800x480, it appears that your monitor is running at 800x600. There are a few ways to fix that. Either change the resolution on your display to it's native resolution (the majority of widescreen 6"-10" screens use 800x480) or if your video card will not support it, you can open up the general.ini in the skin folder and change these lines:
    show width=800
    show height=480
    to
    show width=800
    show height=600
    This will not provide optimum results though, since you will have to stretch certain things, and some things do not stretch (like the GPS overlay) or line up correctly.
    If you can display your monitor at the right resolution, that would be best.
    Also, make sure you have at least the official 11/07 version, the newer beta versions are what the skin is designed for (specifically the 05/08 weatherfixed version) and with it you will be able to access the weather, see solid sliders, and other things that are new since the 11/07 version.
    If you want to post a little more info on your system, I can try and help you get it sorted out.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  7. #37
    Jun 2007
    at first glance, it looks like the lowest setting in windows is 800x600. I'll take another look though when I get back from my trip Saturday afternoon. It's an 8" monitor with a native resolution of 800x600 that can go up to 1024x768 according to the indtruction manual. Model # of the monitor is XDXS080Z, not sure of the brand.
  8. #38
    May 2007
    Lakehood, CO
    ok, looks like you have a 4:3 display. This skin is optimized for 15:9 displays. That's ok though, you can open the general.ini like I was saying and change the info from the previous post I mentioned.
    Issues you will have:
    Labels will not center on the buttons vertically, they will show on the right button, but a little higher up than they should be.
    Album art and other images will be stretched and not in an optimum resolution.
    Menu's may not position in the right location
    GPS overlays will not stretch, so if you need me to, I can post a pre-stretched GPS overlay.
    I was eventually going to make a 800x600 version, but since that's not what I use, it's been put on the back burner.
    Hopefully this helps
    BTW: your monitor is manufactured by Shenzhen Xindaxin Technology Co. Ltd. according to google.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #39
    May 2007
    Lakehood, CO
    I wanted to tweak the skin a little bit. It was sort of bothering me that almost 20 pixels around the entire edge were wasted pixels. The physical edge of the screen is the easiest place to touch, and there weren't any buttons there anymore. I took out the border and made the buttons a little bigger. They are now 121x63 pixels, (104x58 before, 26% larger) and there is no wasted space. Also, I made the fonts a little bigger so that they are easier to read. Here's a screen shot of what it might look like:
    The sliders are going to be tweaked too, I just didn't get to them yet. The songpos will remain, and is a larger clickable area than it looks like, the other two sliders will be put somewhere else.
    I'll have to go through each and every line of code again to get it all to line up and work, so there will be a version 3.0 coming very soon. Since I'll be going through every line of code, I am going to organize the codes better (look at the weather details skin labels for example) so that buttons and labels will be easier to find. I'll also release the PSD's and a help file that will show what each screen is capable of.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #40
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Photoshop PSD's? I could swear you did 'em in paint or some other program.
    Looks good. I'll wait for V3 with all the tweaks before updating again, WHEW!
