Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 100 of 124
Thread: Teknik:T/3 - Released
  1. #91
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    hey ikechun, i really don't know what might be wrong with your setup. I have no way of testing IG4 here, but for skin functionality I used a dummy app and all of the screen switching worked as it shiuld. IG4 runs in windowed mode (embeded) and will go to fullscreen mode on button press. From fullscreen mode it will only return to windowed mode .. and then from there to audio / video etc.
    once you have RR configured to use GPS Menu and have GPSPATH and GPSNAME set correctly i see no reason why IG4 will not run as it's supposed to. I do know from other testers that the skin setup for IG4 works as does the IG4 functionality .. which had problems in TEK2.
    as for the keytbl.ini .. i dont use it, so i cant offer any help there at all ... sorry.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #92
    Nov 2002
    [QUOTE=treetop777;1263234]IG4 works fine. It's something unique in their setup that's causing them problems; i'm fresh out of ideas.[/Q
    Teknik2 (WITHOUT SP2) works just fine on my setup... I've re-installed the OS/apps and started from scratch a couple of times so I cant see what im doing wrong.
    I know ill have to get my hands dirty but you think it would be easy to get the Teknik2 GPS screen to work with Teknik3?
  3. #93
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    @ikechun change the the values of the zoom's to another key cmd , other than 38 and 40 just to try it , i'm just thinking aloud here try it and let us know,
    @tree is your version of ig the reshacked ver, i'm thinking it might be the problem, i'm sure i read that the scripts we use for ig is for the reshacked ver, but can not be totally sure
  4. #94
    Jul 2007
    Ireland
    Quote Originally Posted by carputer1 View Post
    you might just have got it there .. Dr Watson !
    I think you're right about the reshacked versions being needed for the IGLnks scripts ...
  5. #95
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well we will see , my turn for the bug report lol....
    OSK shift not working, i changed to "CAPS" and all is good this was a change alittle while back .
  6. #96
    Jul 2007
    Ireland
    both the "LOCK" and the "SHIFT" are working for me ... which button is not working for you ?
  7. #97
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    No..well..come to think of it..i did hack it to add coordinates, if that counts. I don't use the UMPC version but i have a "themes.ini" that increases the font size of the regular IG.
    Everything work fine with t/3
  8. #98
    Newbie ikechun's Avatar
    Sep 2008
    Los Angeles, CA USA
    Sorry for bother you valheru,
    Somehow theme.ini made conflict with TK3.
    I removed theme.ini and reinstall IG2009 and it works.
    Finally, I can intergrated skin with Factory Navi Bezel button.
    I can use all the button and I am very happy with it.
    Here is the Picture of 2004 Acura TL Navi Bezel run TK3 skin
  9. #99
    Jul 2007
    Ireland
    hey there ikechun, thats looks like a sweet setup alright. It's great that you finally managed to sort out the issues. so the problem was a file from IG then I guess cause TEK3 does not have a "themes.ini" file ...
    is that a custom built bezel .. or one from the manufacturer ?
  10. #100
    Jul 2007
    Ireland
    [QUOTE=Stormbringer;1264210]
    Quote Originally Posted by treetop777 View Post
    Hey Stormbringer .. have you had any luck sorting out your IG issues ... did any of the posts for ikechun help out at all for you ?
