Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 124
Thread: Teknik:T/3 - Released
  1. #101
    Newbie ikechun's Avatar
    Sep 2008
    Los Angeles, CA USA
    Quote Originally Posted by Valheru View Post
    hey there ikechun, thats looks like a sweet setup alright. It's great that you finally managed to sort out the issues. so the problem was a file from IG then I guess cause TEK3 does not have a "themes.ini" file ...
    is that a custom built bezel .. or one from the manufacturer ?
    Theme.ini came from DFX4.0(I used this skin before TK3...Never tought it was the problem.).
    Bezel that you saw came from 2004 Acura TL Navigation.
    I have 2004 Acura TL without navigation and bought Navi Bezel from E-Bay.
    That is why I like to use the buttons from factory bezel with PC.
    I am so happy with it.
    Thank You Valheru,
  2. #102
    Nov 2002
    [QUOTE=Valheru;1264583]
    Quote Originally Posted by Stormbringer View Post
    Hey Stormbringer .. have you had any luck sorting out your IG issues ... did any of the posts for ikechun help out at all for you ?
    Nah, I kinda gave up! lol
    ikechun's issue sounds a little different then mine and im working with a fresh install of ig4... ill try replacing the theme.ini and see what that does but I dont see why that would make the gps selection window keep popping up when im in the other menus.... I'll check tonight about that file... I also found a web site with the "reshacked" (whatever that is) version of the UMPC.exe and that didnt seem to make a difference either.
  3. #103
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    Quote Originally Posted by treetop777 View Post
    I can choose a logo..but where will is show? Also, i get this:
    I'm getting the same error. At some point I got it to change on my desktop (it won't let me change it now) and the Carputer is stuck on "Skoda"
    It's not that big a deal, it's just bugging me that it worked once but not now.
  4. #104
    Feb 2008
    TEXAS
    All it took to fix it was to post up here that I couldn't get it to work.
    I changed it in the Skin.ini and restarted RR... it still showed Skoda, but then it let me change it to Hummer from inside RR. Thought I had tried that once. Oh well, it works now.
  5. #105
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    hummm .. it must have been the thought of being "given out about" on the forums that made it work ... lol.
    I'm glad it is working for you tho ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  6. #106
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    1st off.... I really like the clean layout with nice large buttons for easy naviation -- very well done.
    However, I have a couple of issues I was hoping to get some help with.
    1. After running the theme, winamp starts to crash -- and I mean a lot (like within minutes after starting up). More specifically, winamp seems to become corrupted (ie: running winamp by itself still has it crash). Prior to running the theme winamp and rr work fine. I do have rrmediadb installed (using dfx4) and was wondering if there could be some incompatiability between the two?
    2. IG4 opens full screen and covers all the buttons (so no way to get to anything else while it's running....)
    Any help for us slow people would be apprecaited.
    Nasa
  7. #107
    Sep 2008
    Los Angeles, CA USA
    Quote Originally Posted by nasa View Post
    Nasa
    I had same issue before except winamp.
    In my experience, DigitalFX 4.0 is the trouble when you switch from DFX4.0 to Teknik t3.
    It must be .ini modifications and some files comes with DFX4.0.
    For best solution is remove roadrunner, Digital FX4.0, IG4, and Winamp from computer and fresh install all those that include Teknik T3(which I Did).
    Some hotkeys setup in keytbl.ini doesn't work well with skin I guess it must be front end related issue, but I have to check more on those.
    I belive that will fix your problem.
    Oh, by the way on the IG4 better not using theme.ini(that comes with DFX4.0) and reshacked iguidance.exe or iGuideanceUMPC.exe file it create some issue(Random Issue).
    Teknik T3 use less CPU and Memory means faster reponses than other skin.
    hope this will help.
  8. #108
    Aug 2007
    First of all, let me say thank you for one of the best skins out there, IMHO. I discovered it some days ago and liked it immediately. My carputer, not yet shown here since it's a WIP, is running a slightly modified version of TK3, mainly a translation to Italian (not yet complete), plus some minor changes. And thus, here comes the second thing I want to say: I badly need a blank gameselect_off.png, i.e. the image only, without anything written on, especially in the central circle where it reads "Games Selection". Can I have it, please? I would really appreciate it, as that's maybe the last important thing left to complete my work. I have read that you did it in MS Visio, but then you just need to delete every writing and finally save to PNG.
  9. #109
    Aug 2007
    Forgot to say, in case you're willing to help me, my mail address is just like my nickname, add @libero.it
    Thx
  10. #110
    Jul 2007
    Ireland
    Check your email ...
