Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 111 to 120 of 124
Thread: Teknik:T/3 - Released
  1. #111
    Aug 2007
  2. #112
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    I guys,
    I am now a user of this beautifull skin...but I ran into a small problem when I installed the PC in the car.
    It was running perfectly on my testing bench and I setup all options without hassle. The only thing I changed from workbench to Inside the car...is the driver of the touch screen.
    I setup the computer in the car, then installed the Xenarc drivers without problem.
    Now I was ready to start RR and give it a little play arround in the car....but when I start RR, the skin loads.......and I get a screen saying that RR is quitting with a message saying that we can use this software only for personal use ....blabla i'll try to get a screen shot later this week....
    I tried to reinstalled RR ....and it didn't fix the problem....I thought it was a skin problem....let me know if you guys had the same problem.
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
  3. #113
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by VmtSquad View Post
    I guys,
    Your system (computer) date in the car is wrong.
  4. #114
    Newbie ikechun's Avatar
    Sep 2008
    Los Angeles, CA USA
    Try mitch's sep-08 installer version.
    I have some issue with guino's newest version so I remove and reinstall mitch's 09-2008 rr installer.... works like charm.
    ____________________________________
    2004 Acur-TL - CAR_PC
    1965 Mustang - Fun Drive
    2004 Sequioa - Family Fun
  5. #115
    Jan 2009
    Hello,
    I have installed this theme, and like it for it's simplicity and ease of use.
    However, I have a couple of problems.
    1) Even with the updated files, I still do not get the text in the weather display on the buttons on the right side. I have confirmed that the fonts are in the windows\fonts directory, and downloaded the updated data files. I've restarted RR a few times. No dice...
    2) I would like to change what options are in the main menu area. I'd like to move "Radio", "Settings", and "Exit" to Menu2, and move "DvD", "Photos", and "Weather" to Menu1 in their place. Since I'm fairly new to RR, I'm not sure if this is easy or difficult...
    3) In the top bar, it shows the artist that's playing currently. Is it easy to change it to the song name instead?
    And Finally,
    4) I have no intention of using the activewinamp plugin. I don't much care how many times I've played a specific song. Is there an easy way to remove the "This song has been played 4 times previously" from the bottom of the screen? While I'm at it, can I remove the Star Ratings as well?
    -ET
  6. #116
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Quote Originally Posted by ETMegabyte View Post
    Hello,
    And Finally,
    -ET
    1. I'll look at why you don't see the day text on the weather screen. not sure at the moment. Is the skin folder called "Teknik T-3", and have you the $skinpath$ vsariable correctly set in RR.ini ?
    2. This would require a redesign of the screens to change the location of the icons. Not something that I currently have the time to do.
    3. The top bar is designed to show "artist - song", as displayed in the screenshots in post #1. If it's doesnt fit, it must be that the artist name is very long.
    4. You can run tis without ActiveWinamp, you will loose the ratings fucntion and the search function too, as both of these depend on activewinamp. Simple edit the exectbl.ini if the skin folder and comment out the line that starts with "ONSONGSTART" .. this will stop the rating function from running.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  7. #117
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    I hate to hit you with a 1-2 punch, but this thread coming up again reminded me of a couple questions I had for you at a time I wasn't driving.
    1) Is there a way to switch the radio from FM to AM?
    2) Is there a way to minimize RR?
    BTW: It's still my favorite skin.
  8. #118
    Jun 2008
    Hmm everytime I select a new background RR disappears then comes back up say System default loaded and its just the normal blue background?
  9. #119
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    make sure the paths in rrconfig and the skin.ini are the same
  10. #120
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by txspazz View Post
    1) Is there a way to switch the radio from FM to AM? no! unless we missed that 1 lol..
    2) Is there a way to minimize RR?No! but very easy to add your self, via skin editor
