Page 9 of 15 FirstFirst 123456789101112131415 LastLast
Results 81 to 90 of 145
Thread: New Age Garmin - FINAL RELEASE 01OCT09
  1. #81
    Jul 2006
    Doing it
    Quote Originally Posted by ThunderStick View Post
    If I can get this figured out for radio, XM and Music or anything else for that matter shouldn't be a problem and that would be prety damn cool to have a pop up Ilist with large print.
    I was thinking it would mirror the same functionality as you are already doing with Music. When you hit the music button it opens a pop-up (for lack of a better term) that has a list of the music in the current play list. Or if you hold down the music button to add music to the play list.
  2. #82
    Nov 2004
    St Louis
    O.K., this is quick and dirty. I'll let ThunderStick take it from here. The attached includes a new radio_player.skin, xm_player.skin and a biglist_player.skin. The only change on the radio/XM players was replacing the last preset button to popup the biglist player. This somehow loads the radio.ini or xmcache.ini in the same style as the audio player.
    Issues:
    1. Can't get ilist to work
    2. Next/prev plays next/prev - no scrolling (pgup/pgdn buttons would help, but it still plays whats highlighted)
    3. Need to create "BYVAR" code to change the biglist_player labels from the radio labels to the XM labels.
    Attached Files Attached Files
  3. #83
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by montgomeryt View Post
    The way that is working is It uses the audio command to initiate the audio player (needed to auto turn off radio or what ever was on before) then exits the skin file then reloads using a MENU command instead so that it loads ontop of the main menu screen. This will not work when just trying to enlarge the ilist. You still need the radio_player.skin fle in order for the correct playlist to display. Cant have two seperate ones. Carputer1 gave me an idea that may work, and I will take a look at what Gizmo has and see what I can come up with.
    Expect an update soon, with enlargable ilists on the picviewer, music menu, radios, anything with an ilist now. This is definitely a needed and very cool feature.
    New Age Garmin - Skin for RR
  4. #84
    Aug 2006
    West Allis, WI
    GOOD NEWs
    Guess what I found in my pile of crap computer parts, XM-PCR USB radio. Now I can test out the XM skin.
    BAD NEWS
    Cant get the ilist to work either. I tried using the loadlist command to load up the xmcache.ini with no luck. I did add a button for the biglist popups thought on both the radio and xm screens.
  5. #85
    Nov 2004
    St Louis
    GOOD NEWs
    BAD NEWS
    If you can't find a way to get the ilists working, you're gonna haveta widen the popup screen and add up, down, pgup, pgdn buttons to the left of the list. To me it was no big deal for the radio (12 presets), but XM is a totally different story.
  6. #86
    Aug 2006
    West Allis, WI
    OK got it figured out, check it out in the first post.
    Uploading now
  7. #87
    Sep 2008
    This is a great skin for us Garmin users! I have a quick question. Has anyone had an issue when they fire this skin up of getting error messages? I get three errors made up of 2 of the same and 1 unique. They are:
    First:
    Line -1:
    Error: Variable must be of type "Object".
    Second (Happens Twice):
    Road Runner must be running for this to work
    Also, I have never gotten the backgrounds button to work. It always crashes RR. I have it set in RR and in this skin's skin.ini but it doesn't work. If I go set it statically it will showup but I can't browse them.
    I know this seems like a lot, but lastly, if I try to register the plugins i get an error for all of them saying: "LoadLibrary("whatever dll it tries.dll") failed - The specified module could not be found."
    I love this skin otherwise. Please help me get it figured out!
    Thanks a TON!
  8. #88
    Aug 2006
    West Allis, WI
    Quote Originally Posted by JQFletcher View Post
    First:
    Line -1:
    Thanks a TON!
    More han likely you are using the Road Runner version of the skin with the newest version of Road Runner, Which is Rider Runner. Ride Runner is not backwords compatible with my skin because of the scripts that I use. Download the Rider Runner Skin and try this. If you are using the Ride Runner Version than try the other Road Runner version. This should clear up your problems.
  9. #89
    Aug 2006
    West Allis, WI
    New Release = Bug Fix for Movie Times Navigation and Big iLists in Radio and XM
  10. #90
    Aug 2006
    West Allis, WI
    New youtube preview updating now...
  1. Garmin Mobile PC
    By ptk in forum Garmin Mobile PC
    Last Post: 08-27-2009, 05:05 PM
  2. Replies: 16
    Last Post: 03-18-2009, 04:03 AM
  3. Replies: 72
    Last Post: 07-19-2008, 12:28 AM
  4. Replies: 11
    Last Post: 01-31-2006, 04:37 AM
