Page 11 of 24 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 240
Thread: Carwings
  1. #101
    Sep 2006
    Lancaster PA
    No prob, thought I may have messed up the PM, so I posted here.
    Thanks!
  2. #102
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    New DL in post 1 with too many fixes to list.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  3. #103
    Sep 2006
    Lancaster PA
    Installed last night, and I like it! Need to install the exit menu, but otherwise it is nice. Any way to darken the time/date, it's hard to read in the daytime, white on gray.
  4. #104
    May 2005
    Lawrenceville GA
    Quote Originally Posted by jswalls110 View Post
    Instructions are included to enable exit menu if you need help LMK. You can edit the skin files directly to change color to all black. It is set up with white text and black shadow effect. If you installed RR withthe latest installer then you have the skin editor and you can open the skin and select those fields and change to any color you want.
  5. #105
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I like the original dimmer menu better, not too sure I like the click and hold to exit the dimmer, but hey it works. Other than that, very good! Installed it yesterday and still have not found any bugs, keep up the great work fixer!
  6. #106
    May 2005
    Lawrenceville GA
    Quote Originally Posted by blk02si View Post
    I used the timer version to keep the theme of the skin the same. I can add the other style as a choice or shorten the timer so it disappears quicker. The fewer the keypresses the better in my opinion. Thanks for the testing and feedback. When others chime in we will get a consensus and I will go with the majority because I do not even use the feature.
  7. #107
    Apr 2006
    Sydney, Australia
    not sure what is going on, but after a new install the detail bar on the bottom were is shows volume, for some reason when I'm at 100% the percent sign gets chopped?
    Is this a flash problem on my machine?
  8. #108
    May 2005
    Lawrenceville GA
    [quote=Kosti;1274175]not sure what is going on, but after a new install the detail bar on the bottom were is shows volume, for some reason when I'm at 100% the percent sign gets chopped?
    Fix added to first post. DL and overwrite bottomtext.txt in skin folder.
  9. #109
    Sep 2006
    Lancaster PA
    I had to change computers and drives in the car, reloaded RR and Carwings Dynamic to the latest.
    The issue is Sirius. It plays, but I get a black box instead of a channel list.
    I can change channels using the up/down arrows and select.
    Everything else seems to work as expected.
  10. #110
    May 2005
    Lawrenceville GA
    Did it ever work or is it since you changed drives?
  1. Native Reminder Function Beta Thread
    By Sonicxtacy02 in forum Road Runner
    Last Post: 09-25-2008, 01:44 PM
  2. Blades Edge - Beta 1 Release
    By ThunderStick in forum RR Skins
    Last Post: 09-11-2008, 09:57 PM
  3. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  4. Beta Release Black Vinyl on Aluminium
    By kpjuk in forum RR Skins
    Last Post: 07-31-2006, 10:34 AM
  5. any news on beta release for the front end?
    By bertybassett in forum V.O.I.C.E.S
    Last Post: 05-20-2004, 04:17 AM
