Thanks for the skin, it looks great! Is it easy to substitute Road camera HD for the RRcam plugin? Do I need a new skin for that?
thanks!
Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
Skin: MetroSex on the Beach preview
07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
When I hit the iGuidance button the application loads with no problems and the controls work perfectly. However, is the top and bottom portion of the iguidance window suppose to site above the skin? Should this app at this time be truly embedded? I checked rrconfig and chose that option. Somone enlighten me please. Thanks
Did anyone use CarwingDynamic with Street&Trips?.
som one asked for Road Camera HD integration... my V1 does not support commands so if you wanna do that you need to alow buttons to be pressed.
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Acura / Honda A/V CarPC Adapter GA-NET+ - Convert your native navi DVD unit to CarPC + Dash buttons are usable in car pc!!!
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
I'm having trouble getting my Garmin to load.
I already long clicked the button and switched it over to Garmin. I also have my GPS set to External and the proper path selected to point to the Que.exe for Garmin in RR Config. When I use the button as IGuidance, it loads Garmin fine but with the left hand IG overlay. When I long click and change the button over to Garmin, Que.exe never loads. The overlay loads and it just sits there on the "One moment please" screen, never loading Garmin.
Edit: Just found something out. When I have Garmin already running (Que.exe) before loading RR, then it works just fine. Curious...
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
So how can I get rid of that iglnks that block's the menu button in Iguidance? I'm more comfortable with the menu button, sorry if it's something painfully obvious, but after some minor checking in skin files, and with the editors I just found out what the app it's called, but not how to stop it from being called up. Yes I'm a noob in this whole skinning thing.
