Fixer, have you figured out a way to edit the main menu from within the skin?
I'm looking forward to playing with GMPC with the OSK. I've been too lazy to get it working on my own.
TrafficCams plugin version is out
http://www.mp3car.com/vbulletin/rr-p...-released.html
I'm sure you have it already.
Upd8 is the one you are waiting for.![]()
I can do that but then we lose the "depth" of the letters. I like the look of the drop shadow effect so ...
It is already set up to use GMPC. If you download the files and follow the directions supplied with it it will work out of the box. Single clicking the nav button launches IG and click and hold Navi button launches GMPC with the overlay.
I just did a "clean" install from the new installer and added this skin and you are right it does not work unless you have
backgroundpath=C:\Program Files\Road Runner\skins\Carwings_V2_Transparent\backgrounds
in your rr.ini
background is specified but not backgroundpath is not. This skin uses the backgroundpath command. I believe DFX uses the background command though, so they can be set to different directories without any problem. After I added that to my rr.ini the image preview worked fine. Thanks for pointing it out and I will add it to the instructions in the first post.
