Page 5 of 24 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 240
Thread: Carwings
  1. #41
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    but that's it you use the BACKGROUNDPATH method ofr BG's. Personally I have never got that method to consistantly display EVERY image in my BG's folder .. the PICSVIEWER skin does ...
    edit : all my BG images are std 800x600 jpg files.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #42
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You might want to check the image attributes. It is impossible to show one and not the other unless it is hidden.
  3. #43
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by GizmoQ View Post
    I hope you didn't take my rant the wrong way. I'm not telling you or anyone else how to skin for RR. Its just that standards are being agreed upon by some and maybe they're not distributed or explained to the masses (Stickyed or FAQ). And if they were known, skinners would have to add documentation, for example, that says "there is a directory of backgrounds as a sub directory of this skin that should be copied to your backgroundpath directory, if you don't have one already step1,step2,step3,... is how to create one". Maybe the standards should have boilerplate for skinners to add to their documentation. I don't know. I think I start a new thread on this and try not to get banned.
    :Back to your regularly scheduled programming:
    I did not take it the wrong way. I AGREE! We just need to al get on the same page.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  4. #44
    May 2005
    Lawrenceville GA
    Quote Originally Posted by MGD View Post
    If all skinners would use the $BACKGROUNDPATH$ in theire skin, you can have your backgrounds where ever you want. All you have to do is to specify it in rr.ini.
    backgroundpath=where ever
    I agree this is the best way to handle it. That is why I did mine this way. Maybe we can add the creation of a backgroung folder in the RR installer and put a default image there so all will work out of the box. It would not add too much to the installer size.
    Am I wrong or is RRconfig not handling backgroundpath correctly. I see where background is eet but not the former. Maybe it is my version but I did an install with the latest official version and I had to manually add it.
  5. #45
    Nov 2004
    St Louis
    Keep in mind also that the way the skinner codes the save routine also needs to account for "backgroundpath" definitions that may not necessarily be in the skinpath or rrpath. I had to edit both the background.skin and exectbl.ini cause the SD,,,,, and SAVETOSKIN commands thinks my backgrounds are in the skinpath.
  6. #46
    May 2005
    Lawrenceville GA
    new version in post 1
  7. #47
    Nov 2004
    St Louis
    Having started a new thread on standardization, I yield to the representative from Georgia. All my backgrounds will be moved tonight to C:\Program Files\Road Runner\Backgrounds\.
    Done.
  8. #48
    May 2005
    Lawrenceville GA
    Done.
    I just updated this skin to be compliant with these rules also. I think this will be good for everyone.
  9. #49
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I like the transparent related changes you made in this new version. I even spent the 5 seconds it takes to get garmin mobile up and running.
  10. #50
    May 2005
    Lawrenceville GA
    Traffic Cams added!
    Be sure to download the files from the authors website and follow the directions included.
    http://www.mp3car.com/vbulletin/othe...-v1-2-7-a.html
  1. Native Reminder Function Beta Thread
    By Sonicxtacy02 in forum Road Runner
    Last Post: 09-25-2008, 01:44 PM
  2. Blades Edge - Beta 1 Release
    By ThunderStick in forum RR Skins
    Last Post: 09-11-2008, 09:57 PM
  3. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  4. Beta Release Black Vinyl on Aluminium
    By kpjuk in forum RR Skins
    Last Post: 07-31-2006, 10:34 AM
  5. any news on beta release for the front end?
    By bertybassett in forum V.O.I.C.E.S
    Last Post: 05-20-2004, 04:17 AM
