Page 10 of 10 FirstFirst 12345678910
Results 91 to 97 of 97
Thread: TEKNIK v4.0 [Released]
  1. #91
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I suppose we can't use WMP with this skin, right?
  2. #92
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by RipplingHurst View Post
    You can use WMP for audio and/or video with ANY skin -- even the oldest existing skins. All you need to do is select WMP in RRConfig and choose the skin you want as usual. I only suggest you look at the comparisons of audio/video players in the plugins section first.
    Ride Runner RR's Myspace
  3. #93
    Dec 2007
    Danville, CA
    Okay. I was concerned about all the things to install that are specifically to winamp, since I'm not using it anymore. In particular this, from the list of features on the first page:
    " ...Lyrics, Ratings, Library Search, ..., Delete Current."
    So this will work with WMP? Great!
  4. #94
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    I doubt it ... the search facility uses the media library which is part of Winamp as is the tag editor. delete_current probable does not rely on WA.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  5. #95
    Dec 2007
    Danville, CA
    I thought the tag, ratings feature modified the files directly (not winamp library). I really need to have the ratings things going on, it's great when you rate a song you downloaded, in the car, in the airplane, office, in the car, and they're all consistent.
    It is great if you aim for that that the files themselves get moddded (tags), and not some ad hoc library. Most libraries can read/import the tags from the files, so that helps.
    I'll try it anyway and see what happens.
  6. #96
    Sep 2009
    Shuffle songs
    Is there any way to toggle shuffle songs on/off? Thanks.
  7. #97
    Jul 2007
    Ireland
    Yes you can ...
    Go to the "List-Mode" player, and select the SORT option. This popup's up a menu form where you can change the settings for both Shuffle and Repeat.
    Valheru.
    PS .. This has been greatly improved in the next release, which is coming soon.
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 08:58 PM
  2. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 07:59 AM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 12:23 PM
  4. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 09:50 AM
  5. Replies: 4
    Last Post: 11-29-2006, 01:57 PM
