Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 97
Thread: TEKNIK v4.0 [Released]
  1. #31
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this skin dos'nt have a minimize button , you can add 1 yourself vai skin editor
  2. #32
  3. #33
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    oh yes and Enforcers well know Notepad lol...
  4. #34
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    The skin doesn't have a minimise button ,but as carputer1 mentioned it's easy to add one yourself ...
    When working on the design I wanted the TEK skins to be easy to use in-car, and things like minimise didn't really fall into the easy to do in the car ...
    one very easy to do this is to edit the "topmenu.inc" file with notepad and replace the line
    B03,683,01,115,56,"LOAD;mixer.skin","" with this line
    B03,683,01,115,56,"LOAD;mixer.skin",@MINIMIZE@
    Doing it this way will add a hidden minimize button to the volume button on most screens ... press and hold the volume to minimise the skin.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  5. #35
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    I like the look and all the integration of this skin.
    However, I'm having a couple of issues.
    First off, I hate having to click on the volume button every time I want to adjust volume. I'm thinking it would be better off to have vol+ and vol- keys some where on all screens.
    Also, when using Garmin Mobile PC (external) the GMPC window takes up the entire screen. In order to get out of Garmin and back to RR I have to close GMPC (via the x). This is pretty much a deal breaker for me. I would like to be able to switch back and forth from Garmin to RR and have volume and track controls while Garmin is open. Having to close it every time means I have to wait for it to load again each time I want to check my route.
    Thanks!
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
  6. #36
    Jul 2007
    Ireland
    hi ronjon228 ...
    firstly, for the volume it wold require a complete redesign of the skin to add vol controls to all screens ...
    as for the Garmin, TEK4 was designed to fully handle integrated GMPC software. For it to work you need to do the following ...
    ... In RRConfig, go to GPS screen, and set the "GPS Path" to the exe for Garmin.
    ... Set the GPS Window Name to "Garmin"
    ... Set the GPS Mode to "Menu"
    and then inside TEK4 on the GPS Menu select Garmin ... this will load Garmin Mobile with an overlay that allows switching between Garmin and RR ...
  7. #37
    Dec 2005
    Grand Blanc, MI
    Awesome, thanks Val.
    The volume thing may be a deal breaker for me, but I'll give the skin a shot.
    Thanks!
    CarPC:
    Sound System:
  8. #38
    Jun 2008
    Get yourself a Griffin powermate for volume control.Works great with that one.
    I use turning for volume, pressing for mute and long press for hibernation.
  9. #39
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by ronjon228 View Post
    Thanks!
    What is it with the 'Deal breaker' phrase people keep using with skins and front ends, especially free ones.
    Where is the deal if the software is free? use it or don't use but don't say something is a 'deal breaker' [/RANT]
    NB this is not a dig specific to you ronjon228 as I see this phrase used quite often on this board by other as well.
  10. #40
    Dec 2005
    Grand Blanc, MI
    Quote Originally Posted by Enforcer View Post
    No worries bud, I completely understand. Trust me, I'm the first to praise all you guys for your hard work. I've stuck with free front ends this long and am really hoping I can find a skin (other than carwings) that gives me everything I'm looking for. At this point it's either RR or CF and I don't want to pay for a front end.
    The only reason I used that term is because it's true. I don't have any external volume control and am constantly adjusting the volume. In my case I can't live without a readily "pushable" volume control at my disposal.
    This by no means knocks your skin. It's a beautiful skin for sure. Hopefully you understand now. Keep up the good work man.
    CarPC:
    Sound System:
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 08:59 AM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  4. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  5. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
