Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 97
Thread: TEKNIK v4.0 [Released]
  1. #51
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Quote Originally Posted by monte_q View Post
    All versions of your skin just great nice setup i was wondering if i could get some help setting the date my computer date is correct but the date in the skin is off thank up.
    Can you explain this one a bit more please ?
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #52
    Oct 2007
    nice skin. i like it.
    i not use radio. how to change radio to camera function?
    thanks
    tangkas_baru
  3. #53
    Jul 2007
    Ireland
    camera function ... this is currently not available yet in TEK4 ... but may be soon ...
    do you mean reversing camera ?
  4. #54
    Jan 2008
    date
    I dont have a gps connected to my computer but i cant seem to get the date on the skin to match my system date the time is correct but not the date its stuck on the 23 feb
  5. #55
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    i see the same the date is not being produced, i'm stuck on 21st feb 2009.
    which RR are you useing, also open tek skin folder go to support Rateings folder and double click the rateings.exe the date will change , the rate script is not getting launched on skin start thats all.
  6. #56
    Jul 2007
    Ireland
    the issue is that the "ONSONGSTART" in not being executed on your system for some reason. This command calls the AI script to read the songs rating, but also does one or two other thing, like set the custom date variable.
    Is it possible that you may have another "ONSONGSTART" running somewhere .. like in the RR Exectbl.ini file ???
    Do you have activewinamp installed and the media library configured on your system .. this is "needed" for the ratings to work .. and also for the "rate.exe" to run properly ...
  7. #57
    Jan 2008
    Ok i hadnt done the ratings in the support folder yet i have just install the latest ride runner i will try that tonight and keep u guys posted thanks for pointing me in the right direction
  8. #58
    Jul 2007
    Ireland
    The ratings do not depend on the version of RR ... you need to install and configure Active-Winamp which is included with the TEKNIK4 skin, it's in the "Help Files -> Ratings" sub folder. If this app is not installed on your system then the date (as well as your ratings, and playlist position saving for the multichanger) will not work at all.
    Oh BTW, this skin also required Winamp 5.13 - as Active Winamp does not function correctly with v2.95.
  9. #59
    Jan 2008
    fixed
    Ok thanks guys i installed it and it all works now you guys are great thanks for taking the time to help me
  10. #60
    Nov 2007
    GMPC issues
    Great skin - best I've found so far. Couple of issues though -
    1. System just flashes and disappears
    2. GMPC screen sometimes results in Autoit error "Varialbe used before initialization" or something like that
    Any ideas?
    EPIA NX15000G, OCZ 128GB 2.5" SSD, 1Gb RAM, 7" anti-reflective, transflective touchscreen, M1-ATX, HD-Radio, Bluetooth, GPS, WiFi, USB DVD+-RW.
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 08:59 AM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  4. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  5. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
