Page 8 of 10 FirstFirst 12345678910 LastLast
Results 71 to 80 of 97
Thread: TEKNIK v4.0 [Released]
  1. #71
    Apr 2009
    I have tried that, but it still tries to open the external and does not give me any options.
    I am also getting an AutoIt error sometimes when i click on the top menu bar:
    "Line 1: Error: Variable used without being declared"
  2. #72
    Apr 2009
    OK, i can get it working by opening sygic drive before opening road runner...but i cant change the ExecTBL file in a way that would open it up through the skin..
    I can change the shortcut on the desktop to open them both at the same time, so all is good. :-)
  3. #73
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Hi Ambush ..
    With RRCONFG you must set GPS Mode to "Menu", and you must enter the PATH and NAME of your chosen GPS program. On the TEK4 GPS menu select your chosen GPS program. Only use "External" if your chosen GPS is not one of the other supported options, but again, you MUST enter the NAME and PATH of your chosed GPS program for the GPS screens to work correctly.
    Try this and let me know how you get on ...
    BTW .. glad you like TEK4.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  4. #74
    Jun 2008
    Illinoise
    Will GMPC work on Tek4 with screen transitions at all?
    Has anyone gotten it to work?
    Also, anyway to have GMPC open straight from clicking the "satnav" button on Menu1? It seems that if you mistakenly hit another gps proggy from the gps menu, it resets the sat nav button to that new selection. Why can it not do the same with Garmin?
  5. #75
    Jul 2007
    Ireland
    i've seen a lot of comments about screens transitions and to be honest unless your car pc is really powerful i'd leave transitions off ... especially with GMPC.
    on the main menu ... if you press and hold the GPS button it will bring up the GPS menu from where you can set GMPC as your Sat Nav program ... then everytime you hit the GPS menu buttom GMPC will open - provided you have followed the setup listed 2 posts above ... you can also switch to GPS prog from most screens by tapping the top status bar (where the song title is displayed) ...
  6. #76
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Valheru View Post
    ..or you can exclude transitions in that particular screen by copying this to the .skin (courtesy of BlueZX3):
    Code:
    /EFFECTIN=-1
    /EFFECTOUT=-1
    /FORCEEFFECTS=TRUE
    In this skin, i don't know i it would go in garmin.skin or external_gps.skin - would need to be tested.
  7. #77
    Jul 2007
    Ireland
    thats a really usefull little trick - thanks for sharing treetop ...
  8. #78
    Apr 2009
    Hey guys,
    Can anyone suggest how i can get freefone to work with teknik 4?
    Cheers
    Ray
  9. #79
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this will be the buttoncmd to launch freefone
    LOAD;freefone.skin;FreeFone;$skinpath$\FreeFone.EX E;FreeFone
    attached is a skin file with freefone already setup, just drop it into your tek folder and add the button cmd above and drop the freefone.swf into tek folder as well,the labels at the bottom saying freefone is your EXIT skin button,
    should be good to go
    Attached Files Attached Files
  10. #80
    Apr 2009
    cheers carputer...appreciate it
    Ray
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. How To: Get your new skin out to the masses.
    By monkeyracer in forum RR FAQ
    Last Post: 07-19-2008, 08:59 AM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  4. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  5. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
