Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 64
Thread: iDrive F01 -Alpha Release- !!Question to skinners - Post 40!!
  1. #41
    Constant Bitrate WarningSLO's Avatar
    Dec 2005
    San Diego, CA
    Quote Originally Posted by treetop777 View Post
    Share! Share!
    My files are at work, so I'll get them to you on Monday.
    My Worklog
    2006 Tungsten Grey GT | Dark Charcoal Leather | 18" Fanblades | Spoiler Delete
    C&L Intake | Bullitt Mufflers | MGW Short-throw Shifter | MGW Interior Pieces
  2. #42
    May 2008
    Evergreen State
    Quote Originally Posted by Bimmerstyle View Post
    @Kardain:
    That can be a problem indeed. I've never tested the skin with auto Day/Night switch. It's quite normal this won't work with this skin since my Day/Night buttons perform other actions than simply changing Day/Night. <snip>
    Completely understandable. As you stated in your opening post, this is intended to be as OEM as possible... Just if you ever decide to go to auto switching (which, in my opinion, is a great feature), the bug is there.
    I'll play around with the included files to see if removing the overlay function altogether works fine while keeping the left pane at its extended state. However, now that DST is in effect, I don't get the opportunity to hit the auto-switch time.
    I'll still give this skin a thumbs up though, even with the small bugs
  3. #43
    Mar 2009
    beautiful skin man, quick question tho how do i enable Phone support
  4. #44
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    Thanks!
    Quote from first post in this topic:
    Also phone is not supported. I tried endlessly the various plugins available but can't get any of them to work as they should. At the moment I'm completely fed up with phone related stuff. I kept the button in the skin however and there are empty Phone.skin and .jpg files so people who want can create there own phone screen based on those.
    Basicly the answer to your question is: not... Although the button is there, no phone support is present in the skin.
    It's possible in the future I will look into Phone support again (for the gazillioned time) and try to make something work. At the moment... See quote.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  5. #45
    Sep 2008
    Hi Bimmerstyle, any progress with BMW OEM navicontrols?
    BR//Tobmag
  6. #46
    Newbie kruben's Avatar
    Jun 2005
    So Cal
    I-drive control
    Hi do you know if this can be controlled through the I-drive?
  7. #47
    Sep 2008
    Hi Kruben.
    No this is for the old I-bus BMW's, as far as I know there is nothing availible for the I-drive cars.
    BR//Tobmag
  8. #48
    Sep 2006
    Belgium
    iDrive control is not supported altough in theory it can be controlled by anything that can control RR. So if someone comes up with the necessary hard and software to make iDrive control RR, it can be controlled by it.
    Carx24 has a frondend for iDrive cars. But integrating the hardware seems quite difficult from what I've seen of it. Here's a link.
    tobmag, you meen controling it with the OEM naviscreen buttons/knobs. I really haven't done anything with that since I don't have an OEM navi. I also don't know the iBus codes for those buttons.
    The only ones I use are the steering wheel buttons. I have made "on" state screens for the menu's and a modified iBusRR file that uses the steering wheel buttons to navigate through the menus. Downside is that when in any of the menus there is no volume control and track control since the buttons are then used for navigation.
    The only copy of this iBusRR.ini file is in my car. I will make a copy of it and put it online along with the new skin with the "on" state screens in the next couple of days.
    Further than that nothing really has changed to the skin since my last post here.
  9. #49
    Sep 2008
    Code:
    Yes thats right, you will actually find all codes in the CarX .ini file.
    If you dont have the OEM navi in your car I assume it will be difficult for you to develop.....
    There is not really any good front ends out there. CarX is working but way to many bugs, right now Im using CarMedia instead much simplier but without bugs at least:-)
    BR//Tobmag
  10. #50
    Apr 2008
    hi
    Did you include the Ibus plugin in this skin?
  1. iDrive Night Green 2.20 Release
    By Enforcer in forum RR Skins No Longer Supported
    Last Post: 09-08-2010, 10:34 PM
  2. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  3. Alpha Release: XMPC-CAR for XM
    By gork in forum Software & Software Development
    Last Post: 01-11-2006, 01:19 PM
  4. SRC Release frodoxm ActiveX control 0.1 alpha
    By frodobaggins in forum Software & Software Development
    Last Post: 10-08-2005, 08:20 PM
  5. FrodoPlayer SkinMaker Alpha Release
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-03-2003, 10:36 PM
