Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 41 to 50 of 139
Thread: TEKNIK-X [Released]
  1. #41
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    @navputer: I'm not really taking requests but I'll look at whats involved in adding those apps.
    @xylidine99: If you look in the folder c:\program files\riderunner\documentation - there are lots of help files there with info on the RR commands.
    @Lactionaire: Try the two files in the attachment ...
    Attached Files Attached Files
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #42
    Sep 2009
    Thanks!
  3. #43
    Dec 2006
    speed and speedo
    Nice work.
    Do I need to load the Garmin Plugin or is that already included.
    Only thing I would like to see added is speed indication on the screen. Most csr Speedo are out today so being able to quickly check my speed by simply looking at the screen makes life easy.
    Cheers
  4. #44
    Jul 2007
    Ireland
    This skin doesn't need anything other than a working install of Garmin Mobile PC to operate correctly. It uses El-Camino's overlay plugin to draw some control overlays on top of Garmin.
    ... and not for me to sound toooo stupid, why do you need speed ind on RR screen when you have a perfectly good speedo on your dashboard, that is right in your field of view ? Are you saying that your car's speedo is off, of just not correct. Either way I'd hazzard a guess that it;s more accurate and updated more frequently than and speed ind inside RR, even if that ind comes from a GPS signal ...
  5. #45
    Oct 2009
    when i select menu in the rrconfig for the gps and i clicked on garmin after that when i hit the sat nav the menu screen doesnt come up anymore and goes straight to the garmin screen how do i change that?
    also im using igo8 and the program is covering the bottom portion of the screen where the volume controls are and if i click on those then riderunner comes to the front and u cant see igo8 anymore what file do i play with to get igo8 to sit properly
    thanks again sorry to be such a pain..
  6. #46
    Jul 2007
    Ireland
    if you are only using igo8 then you need to set rrconfig to "external", and in the TEK_X GPS menu select external (which only runs in full screen).
    you can reset the TEK-X GPS menu by going to the "Config" options screen, and click to the second config screen, there is an option there to "Reset GPS Menu". This will now set TEK-X to display it's GPS menu until you next select a GPS option. TEK-X is designed to only show this GPS menu once, and as soon as you select a GPS program it remembers your selection and then defaults it's GPS to your selection.
  7. #47
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Where the Mods at? Need to move this to "released" skins.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  8. #48
    Jul 2007
    Ireland
    indee ... but I didn't want to sound tooooo pushy ...
  9. #49
    Oct 2009
    hey i have igo8 set to external and under window name i put igo8 in rrconfig...but the window is not aligned properly in ride runner...which file do i play with to adjust where igo8 sits on the screen?
  10. #50
    Jul 2007
    Ireland
    if you are using the "external" gps option in Tek-X then the skin file is called External_gps.skin. And the line in there that set the location is
    /, GPS Application.
    A01,0,0,800,600,000,$GPSNAME$
    which as you see is set to show the application in full screen.
    I did come across this before but on the visualisation screen ... that screen just wouldn't embed correctly in ride runner. once i reinstalled winamp tho it was ok. I have no idea why igo8 app is not correctly positioned in the screen.
  1. TEKNIK v4.0 [Released]
    By Valheru in forum RR Released Skins
    Last Post: 09-22-2009, 07:32 AM
  2. Teknik 2 Features added
    By fixerofallthing in forum RR Skins
    Last Post: 11-07-2008, 11:10 AM
  3. Teknik v1.0 & v2.0 - RELEASED ...
    By Valheru in forum RR Skins
    Last Post: 10-05-2008, 02:55 AM
  4. Teknik v2.0 - RELEASED
    Last Post: 12-04-2007, 10:22 AM
