Page 8 of 14 FirstFirst 1234567891011121314 LastLast
Results 71 to 80 of 139
Thread: TEKNIK-X [Released]
  1. #71
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    cool ... let me know how it works for you ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #72
    Jun 2008
    The TA and AF buttons dont seem to do anything in AM/FM radio screen.
    When i press them nothing happens.Have i forgot to do something with riderunner or is this a skin issue?
  3. #73
    Jun 2008
    Quote Originally Posted by zanor View Post
    Hi!
    Great skin!
    But is it possible to make Garmin run in background and not close when the exit button is clicked from the gps screen?
    Are you sure that you are running garmin skin(the one that has the overlay skin for osk and other stuff), because when i use that and press exit, i can still hear all the instructions eventough im not in the garmin screen.
    I also added navmute so i can hear the instructions clearly without audio or radio.Its a brilliant little application.
    http://www.digital-car.co.uk/forum/s...77&postcount=1
  4. #74
    Jul 2007
    Ireland
    I don't have radio on my setup here so I had no way of testing this. I did use the new RDS commands - are you running a current version of RR ?
    if that is the case for you Schma then it's an old bug come back to life that I thought I had stomped out. If you press "exit" in the Garmin overlay screen it is supposed to fully kill the "que.exe" task (which is the GMPC executable). The fact that you still hear the garmin commands after pressing the exit button suggests that the killtask step is still not right - even though I was 100% convinced I had it sorted in this release.
  5. #75
    Jun 2008
    Im using the latest rr.The buttons not working is actually not that bad.Just tought that i tell you about this problem.
    Actually im happy that the killtask doesnt work.This way i dont need to be on garmin screen all the time and still hear the instructions. I would say that its a great bug
  6. #76
    May 2005
    Quote Originally Posted by Valheru View Post
    Add these two lines to the file "video_player.skin" .. anywhere before the END command. Once added, you can click the screen on either left or right of the video and you can now scroll thru the zoom modes.
    B00,000,100,55,345,"ZOOM",""
    B00,741,100,55,345,"ZOOM",""
    I have changed the 2nd button to HIDECONTROLS instead so I can utilize my entire screen for watching video.
    B00,741,100,55,345,"HIDECONTROLS",""
    Just need to tap anywhere on the screen to return to the previous screen when playing video in full screen. Would be nice if you can add 2 buttons/icons to the bottom bar for the above zoom modes and full screen function.
  7. #77
    Jul 2007
    Ireland
    for all those who used these functions, here is a modified video player skin with the zoom and hide controls properly integrated ... just unzip and replace existing files.
    enjoy.
    Attached Files Attached Files
  8. #78
    May 2005
    Hi Valheru, would you be able to make a small update to your Picture viewer skin? Currently I have many photos, your skin doesn't allow me to select which photo I want to view and it always start from the first one.
    It would be nice if you can incorporate an iList, something similar to the background selector skin.
  9. #79
    Newbie Blunt's Avatar
    Feb 2006
    N.C.
    First off, I must say great skin. I can't seem to change backgrounds. I'm using the latest RR, but (backgroundpath=)is not in rr.ini file.There is a entry called backgrounds,so i tried that.Backgrounds are not populated in background skin, please point me in the right direction.
  10. #80
    Jul 2007
    Ireland
    Quote Originally Posted by Blunt View Post
    you need to manually add an entry to your rr.ini for backgroundpath, such as ...
    backgroundpath=C:\Program Files\RideRunner\Backgrounds\
    this setting is normally found in the [Extra's] section of rr.ini ... at the bottom of the file.
  1. TEKNIK v4.0 [Released]
    By Valheru in forum RR Released Skins
    Last Post: 09-22-2009, 07:32 AM
  2. Teknik 2 Features added
    By fixerofallthing in forum RR Skins
    Last Post: 11-07-2008, 11:10 AM
  3. Teknik v1.0 & v2.0 - RELEASED ...
    By Valheru in forum RR Skins
    Last Post: 10-05-2008, 02:55 AM
  4. Teknik v2.0 - RELEASED
    Last Post: 12-04-2007, 10:22 AM
