Page 17 of 57 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #161
    Newbie diverdeep's Avatar
    Sep 2010
    Good day, I have a little problem with reborn skin. I've installed on a NetBook with win7 starter. All works fine but, the font is wrong. I have tried to reinstall BMW-E36 font (in fonts to be installed" folder) and it seems to be installed correctly in windows control panel but in RR i see another font (like "comic sans") and is too big.
    Any help?
    Many thanks
    Giuliano
  2. #162
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by diverdeep View Post
    Any help?
    Many thanks
    Giuliano
    You need to install Ericsson GA628 font which most labels use. Only few labels use BMW-E36 font, like PDC and TMS.
  3. #163
    Sep 2010
    many thanks. I find it online?
  4. #164
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Should be in the original E36 download
  5. #165
    Feb 2009
    Finland
    Quote Originally Posted by Enforcer View Post
    And it's in Reborn download.
  6. #166
    Nov 2010
    thank, i'm solved the flashing sygic screen, but i've another problem.
    the volume of navigation instruction is the same of the music.it was up and dw toghether.
    my question is: to solve this problem i must use this command or other?
    "NAVPAUSE","RRVolRamper_Dn;75;30||Wait;2"
    "NAVRESUME","RRVolRamper_Up
    i try but i don't understand how it work.
  7. #167
    Sep 2010
    Done, now all works fine. Thanks!
    Quote Originally Posted by Dartman_71 View Post
  8. #168
    Newbie energyjms's Avatar
    Nov 2010
    Tawau, Malaysia
    Hi to all,im using RR Nov version with Reborn skin on Win7,here is my problem:
    1)There are few button aren't responding when i click on it : CDRip,RRTube,WiFi,PDC,TMS,Email
    2)Is it I hv to install plug in separately in order to keep those button functioning?BTW I've tried installed El Camino's Wifi Plugin but nothing happen either.
    3)How to set the music visualization using only standard winamp oscilloscope visualization?
    Im newbies hope u guys can help me..Anyway this is the most perfect skin i ever found..
  9. #169
    Feb 2009
    Finland
    Quote Originally Posted by energyjms View Post
    1) Buttons not respond if plugins are not installed. In first post and in readme file is list of plugins, also links to plugins threads.
    2) Doesn't matter in which order you install plugins. I'm not sure if those plugins work in Win7 because most plugins are made for XP. WiFi and RRTube may work. I'm 110% sure that Email doesn't work because it's for Outlook Express.
    3) Look RR.ini which is RideRunners main folder, there is "visuname=" add your visualization name there.
    Did you register WiFi plugin? There is register.bat in WiFi plugin folder.
  10. #170
    Nov 2010
    Tawau, Malaysia
    ok thx dartman,i'll try to install all the plug in 1st.Regarding the Wifi plug in,i did regiter it,but still not working..is it win7 issue again?anyone using this skin on win7 without having same problem with me??thx
