Page 21 of 51 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 509
Like Tree2Likes
Thread: Reborn (Updated 5/17/12)
  1. #201
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ok i have just got the latest build from Dartman , and DL'ed the latest winamp,,, i have no problems seeing and playing m4a files
    i assume you have .m4a in audio type in rrconfig
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #202
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    as for your sleep issue , not showing , but is it playing last tracks played ??????
  3. #203
    Newbie energyjms's Avatar
    Nov 2010
    Tawau, Malaysia
    When will the latest Reborn skin release???
  4. #204
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Christmas is coming fast so here's Christmas present in advance, dl it from first post
    Enjoy
  5. #205
    Nov 2010
    Tawau, Malaysia
    Quote Originally Posted by Dartman_71 View Post
    Enjoy
    yea!!!im dwldng my X'mas present now!!!
  6. #206
    Newbie diverdeep's Avatar
    Sep 2010
    good day. I've installed the last update (thanks Dartman! :-)) and also the last RR. After, I've replaced all .INI files and all .skin files, to mantain my setting (buttons, plugins settings, etc)
    Now I have only a problem. The buttons in the lower part of screen (volume + - mute and play , skip etc) is not working correctly. How can I get this button working without loose my other buttton settings? (I attach menu.skin files). Many thanks in advance. Giuliano
    Attached Files Attached Files
  7. #207
    MySQL Error
    Oct 2004
    Quote Originally Posted by voodoolady View Post
    Hello,
    I have been using Reborn since the release and I love it. There are only a couple things that I would like to see in an update. I would like to play m4a's and I would like to see the volume and the track buttons swapped. Not sure how hard that is, but in using it every day for the past months I find my self always having to look down to find the track forward button. Also the only bug I found and I have a feeling that it is a bug that can't be fixed, but when I put my computer to sleep and wake it back up it does not show what was playing and it will not show any of my music, so I need to close and reopen the program (I have seen this with all of the frond ends). Other then that this front end rocks.
    m4a...
    check your rr.ini
    example:
    audiofiles=.mp3,.m3u,.m3u8,.ac3,.flac,.m4a
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #208
    Feb 2009
    Finland
    Quote Originally Posted by diverdeep View Post
    Do NOT replace anything!!! Make your changes to new files if needed. Also you made your program start wrong way.
    Add OZI EXPLORER||OZI EXPLORER to buttonlist.txt file
    Add "OZI EXPLORER","LOAD;OZI.SKIN;;C:\OziEmbeddedV1.0\SKINb edder.exe;OziEmbedded" to ExecTBL which is in Reborn folder
    Add OZI EXPLORER.png image/logo to icons folder... or copy one image in icons folder and renamed it to OZI EXPLORER
  9. #209
    Sep 2010
    Many thanks Dartman! I'll try.
    Giuliano
  10. #210
    Sep 2010
    I've tried with ozi explorer and with compe gps but do not work correctly. The applications run but, not in the correct resolution or "externally" to RR. Maybe I write something wrong? What is the last parameter in string (ie OziEmbedded at the end of ozi explorer string in ExeTBS ??
    Thanks again
