Page 23 of 57 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #221
    Dec 2010
    Dartman,
    Thanks for the tips and your patience. Everything starts looking even nicer now.
    One more question - I got my WiFi button and it loads your skin just fine. But there's nothing displayed. I have the latest WiFi plugin from El Camino in several places (one in C:\ProgramFiles\RideRunner\Plugins, and one in the MyDocuments profile thing folder). Since I loaded so much stuff, everything is everywhere and I'm getting confused. Your Plugin Manager says that I have rrwifiman 1.1.6 loaded and enabled.
    What are the settings/requirements for this plugin to work properly in your skin.
    Thanks again.
  2. #222
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    No worries I try to help as much I can, like other have helped me. I was rolling my eyes when I try to figured out RR and skin stuff first time heh.
    I haven't install wifi stick to seven yet so I can't tell you much. What I've read wifi plugin should work in seven, except you can't enable/disable network. But other features like conneting networks etc. should work. If you downloaded wifi plugin from Carputer1's site then you have newest version, altough it show version 1.1.6 in plugin manager but it really is 1.2.0
  3. #223
    Feb 2009
    Finland
    Okay I installed my wifi stick and wifi plugin. Plugin start to work and show networks and infos in skin. Plugin is installed to RideRunner\Plugins folder like Legacy mode, although I have installed RR in profile mode.
    I seem to have some problems with connecting to wifi network with this M$ creation, Win7 can't do it by it self. Software which came with stick connect right away but interference plugin. OH BOY this is so easy with XP hehehee...
  4. #224
    Dec 2010
    Thanks again. Yeah, I'm a big fan of XP myself... The reason I chose Win 7 for this rig is because I replaced the harddrive with a CF card (poor man's version of SSD) on my UMPC (Q1U) and Win 7 behaves a bit better with it in the sense that it does not read/write endlessly. Also, I use the gizmo as a regular computer when not in the car, and I like the tablet features. Plus, it was difficult to install it on this machine - which makes it more fun
  5. #225
    Feb 2009
    Finland
    Well well... after couple of reboots Win7 start cooperation with wifi stick. About wifi plugin... I can connect and disconnect network, but after reconnecting info labels are empty. Everything else seem to work except enable/disable network.
  6. #226
    Dec 2010
    So I am confirming that the WiFi plugin works just fine with Win 7. I'm a complete moron, I had network cable plugged in, I guess my little UMPC disables WiFi when on LAN. I love that the skin says "Connected to wifi" - it's useful when driving. Now I would love to figure out how to make it automatically connect to whatever open hotspot it finds.
  7. #227
    Jun 2010
    There's a setting in windows networking to do that. Not sure exactly where in Win7 though. In windows xp you could create lists that you wanted it to auto connect to.
  8. #228
    Newbie diverdeep's Avatar
    Sep 2010
    how can be disabled the "click" sound when press a button?
    Giuliano
  9. #229
    Feb 2009
    Finland
    Open ExecTBL from Reborn folder and add / before ONBTNPRESS and ONBTNHOLD. Like this,
    /"ONBTNPRESS","PLAYSOUND;$SKINPATH$SOUNDS\BUTTON1.w av"
    Or delete both lines.
  10. #230
    Sep 2010
    many thanks, I'll try!
