Page 24 of 57 FirstFirst ... 141516171819202122232425262728293031323334 ... LastLast
Results 231 to 240 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #231
    Newbie diverdeep's Avatar
    Sep 2010
    Quote Originally Posted by Dartman_71 View Post
    Open ExecTBL from Reborn folder and add / before ONBTNPRESS and ONBTNHOLD. Like this,
    /"ONBTNPRESS","PLAYSOUND;$SKINPATH$SOUNDS\BUTTON1.w av"
    Or delete both lines.
    Dartman, I've done, but now instead of "click" sound I have another sound....like "bip". What I can do to disable ALL sound?
    Thanks Again
    Giuliano
  2. #232
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by diverdeep View Post
    Thanks Again
    Giuliano
    If you follow my instructions, there's no "bip". If you delete .wav files from Reborn\Sounds folder then you could hear "bling or bip" sound. If you want disable Ladys babble, in configs is setting for that.
  3. #233
    Sep 2010
    I've renamed like this:
    /"ONBTNPRESS","PLAYSOUND;$SKINPATH$SOUNDS\BUTTON1.w v"
    it's the same? or I have to rename .w av?
    Giuliano
  4. #234
    Sep 2010
    I wish to buy a sinto TV (dvb-t) and a sinto FM usb. I have to buy a specific ones or I can buy any?
    Many thanks
    Giuliano
  5. #235
    Sep 2010
    I've buy a USB DVB-t. What I'll need to have it working in reborn? (plugin?)
    Giuliano
  6. #236
    Feb 2009
    Finland
    Giuliano
    You can try if your DVB-T stick works with DVB Viewer which cost 15, also you need DVB Viewer plugin
  7. #237
    Feb 2009
    Finland
    Many thanks
    Giuliano
    And here is radios which are supported in RR.
  8. #238
    Sep 2010
    many thanks, dartman!
  9. #239
    Feb 2009
    Finland
    DVB Viewer should work with all DVB-T sticks which use BDA drivers.
  10. #240
    Feb 2008
    Just switched to this skin from the original BMV2. Love it 1 annoyance i'm having though is with the sliders (volumer and mixer) don't go all the way full when at 100% and goto empty at about 5% rather than 0. Is there somewhere they're configured?
