Page 25 of 57 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 241 to 250 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #241
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by IrmscherV6 View Post
    Just switched to this skin from the original BMV2. Love it 1 annoyance i'm having though is with the sliders (volumer and mixer) don't go all the way full when at 100% and goto empty at about 5% rather than 0. Is there somewhere they're configured?
    Sliders works fine here so I don't see any problem. Can you specify, screen caps...
  2. #242
    Feb 2008
    Screenshots
    Feb 2009
    Finland
    Which RR version you use? Here's mine vol slider, no such issue.
  4. #244
    Feb 2008
    RR ver: 12/12/2010 latest version, there must be a file or something I can change cos that's gonna bug the hell out of me now lol
  5. #245
    Feb 2009
    Finland
    I understand that going to bug you but there's no file or adjustment for that. Slider should go to full when vol is 100% and to none when vol is zero. What os you runing? I don't know if that matter. Have you set your vol to master volume from config?
  6. #246
    Feb 2008
    XP sp3, volume is set to master volume. It's not just the volume slider, does the same with the mixer sliders too, it basically is using slider19.jpg as the max level :S
  7. #247
    Feb 2009
    Finland
    There is slider fixes in newest RR which is not released yet, I'm not sure is this related to that. But like balance slider is not middle when your balance is center is fixed and lots of other old slider issues.
  8. #248
    Feb 2008
    Tried a fresh install of current RR and reverted back to September copy from backup but still the same Can I ask what version you're using?
    Feb 2009
    Finland
    Issue is fixed in RR 12/18 beta
  10. #250
    Feb 2008
    Definately an issue somewhere in RR as I've just installed Simplistique and got the same issue
