Page 27 of 57 FirstFirst ... 171819202122232425262728293031323334353637 ... LastLast
Results 261 to 270 of 562
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #261
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by diverdeep View Post
    Yes Dartman, sorry! Now I've "read" readme :-)
    DVB is working, the only buttons not working are P+ and P- ??
    I have to configure something?
    Thanks and sorry again
    P+ and P- change favorit channels, so you need to make favourite ch list.
    Open DVB Menu and go to Systems -> Settings -> Favourites.
  2. #262
    Newbie diverdeep's Avatar
    Sep 2010
    ok, thks
  3. #263
    Jul 2001
    I just want to say that this is a GREAT extension of robby's original work... Been using it for a few months now and its been rock solid
  4. #264
    Feb 2009
    Finland
    New update 1.08 in the air, hope you like it.
    And thank's to Ces///M3, I'm glad you like it.
  5. #265
    Jul 2001
    Not sure if other users are aware or not, but there is a plugin for mozilla firefox called anycolor that will allow you to tie the color scheme of the browser into this skin (or any for that matter) nicely
    https://addons.mozilla.org/en-US/firefox/addon/6991/
    I'm curently working on getting a bigger screen vis... ignore the artifact this is all on the desktop atm
  6. #266
    Feb 2009
    Finland
    Quote Originally Posted by Ces///M3 View Post
    Thank's for the tip!
  7. #267
    Jul 2010
    Dartman_71, first of all i would like thank you for that skin, after trying all of them on this forum this one looks like is working best with my hardware, great work!
    Only one thing is that i have craig Brass DAB dadio, and need skin for it. Im not a pro, so please forgive me a stupid questions.
    Plugin and skin is included with latest RR, but there is a problem with that sikin, looks like it hangs my comp 1 of 4 times. so useles for me.
    I tried to modify your existing radio skin, for now i just cleared the buttons and addressed the buttons for functions. working great! Im hoping you are ok with me modifying it...
    There is my question, as you see on picture below info about channell curently plaing showing very large letters, i would like have that on the screen on the top, with same color and font as DAB. i will use other area for preset buttons.
    possible?
    thank you
  8. #268
    Mar 2010
    I'm new and sorry to ask such dumb questions but I have a few.
    In the thread people are talking about 'installing' the plugins. I copied the plugins into the plugins folder and went into the rr config and tried to register them but it didn't find them. Also, they don't show up in RR.
    Also, the 1.8 update. I'm confused on how to install that. The readme doesn't help me much there I'm afraid. Maybe I'm just too green. ;-)
    Great skin. Stable as a rock. One Issue I'm having is the sounds when you hit a button are much louder than the music. I'm using winamp latest version on xp. Also, is there a way to lock the volume to windows volume? Sometimes, windows volume has been turned down so low I have to go back into windows to turn it up a bit.
    Once again. Thanks
  9. #269
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by Mycophiles View Post
    You won't find anything like in RRconfig , Download plugins , put the plugin nto your riderunner\plugins\ folder
    most plugins come with a reg.bat or runme1st.bat ,,, this is what you need to reg the plugins,
    also along with the plugins will be some form of help , ie, a RAEDME.txt ,
    what are you actually having issues with
    Once again. Thanks
    this i assume your talking about the button press bleep , this can be switched off, , can't actually rememebr if Dartman , set a switch in his SKIN config, look through the skin's exectbl.ini for "ONBUTTONPRESS" put a \ in front of the line this will stop the bleep..
    as for windows volume , you can set the vol to be a certain level on RR start up . add to skin.ini or rr.ini
    startupvolume=xxxxx ,,, xxx= the % of the volume you want
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #270
    Mar 2010
    Quote Originally Posted by carputer1 View Post
    No real issues. Just doing the update as it was given. The skin has been rock-solid.
    I'm having simple issues as this is my first install. The monitor doesn't 'wake' up after it goes to sleep and such. I haven't looked into that yet.
    Otherwise Just what i've said. I need to do some research on skype and what I can be used for. I don't see me using it. I'd like a google voice app but I haven't even searched for anything like that.
    Like I said the skin is great but I'm still testing it out. Next thing I would like to do is make names of the songs in the list bigger. They are kinda hard to double click, but then again that's another feature in XP I need to look into.. single click select. lol
    See, I'm pretty green. Ohh.. one more thing. Do people take the ini file and edit it on their computer and then copy it into the carputer just to make it easier? Any walk-through on this? Do I need to read the skin-editor EDU?
    Appreciate the quick response. ;-)
    edit: how exactly do I 'runmefirst.bat' a file? How do I select it to run? From within RR or from the windows environment?
