Page 3 of 52 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 514
Like Tree2Likes
Thread: Reborn (Updated 5/17/12)
  1. #21
    Newbie dongzhi's Avatar
    Feb 2010
    CHINA
    Good ,i like you
    All the distinguished predecessors:
    I am a beginner, English is poor, may be the future I can to create the skin, it is because of your help, thank you.
    My computer is viliv x70ex ,windows 7.
  2. #22
    Registered User
    Jan 2010
    Great job Dartman_71 !! I was thinking of doing some upgrades to my skins but now I don't have to. All is working perfectly. Awesome
  3. #23
    Feb 2010
    CHINA
    Dartman_71 sir:
    Can you tell us you are now using the operating system, touch screen, what is resolution?
    At the same time, I also want to know what your music player, as well as what video player?
    I would like to here, I better know how do I run under my WIN7 How do I set to the best.
    I am now a little run on the issue, I am trying to check the information and to learn to do better.
    For example, the debugging information display is not found in MIC? When I change to another player when the machine pause occurs, only forced to close RR.
    I think we should set up my issue, but also WIN7 the problems brought about
    Thank you very much works
  4. #24
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by dongzhi View Post
    Dartman_71 sir:
    I use WinXP, I can't help you Win7 related issues sorry. Skin is intended to use with 800x600 resolution and 16:9 aspect ratio screen (Wide screen). Audio player tested with Winamp and WMP. Video player tested with WMP and built-in players.
  5. #25
    Constant Bitrate vull's Avatar
    Oct 2007
    microsoft has released the cure for all win7 issues -> win xp
  6. #26
    Feb 2010
    CHINA
    Quote Originally Posted by Dartman_71 View Post
    Thank you, I would like to know, you can compare studies, the unique WIN7 on my problem how to modify it.
    First of all first contact with the RR, on the use of your SKIN, Enlightenment-style learning, again, thank you.
  7. #27
    Oct 2009
    This skin is very nice. Good job!
    I upgraded to the latest version, but now the Goggle Earth button don't work; it don't load the google skin. With the first version of the skin no problem.
    Another problem about Youtube skin, when I push the play button to see a video of the list, I don't see it.
    I use WinXP.
    Thanks.
  8. #28
    Feb 2009
    Finland
    Quote Originally Posted by fepra View Post
    I use WinXP.
    Thanks.
    Thank's
    That's strange, I didn't change anything to GE. Check buttonlist there should be GE||GOOGLE EARTH and in exectbl should be "GE","GE_START||GE_EMBED"
    Try set button again, if that not help delete reborn folder and download full skin again.
    About Youtube problem, Carputer1 have same issue, problem to load player. I have Youtube working on two machines both with XP and no problem. I really can't say is it codec issue or what.
  9. #29
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    Hi, I'm now installing this skin. A tiny problem: the installer doesn't care what folder you select, it still installs th eskin in C:\program files\riderunner\skins
    (win 7)
  10. #30
    Dec 2007
    Romania
    Any idea what the problem might be? Whenever I try to change color scheme, or the car logo, I get an error, something like Variable must be object type.
    Again, win7 might be the one to blame.
    Further, the volume control doesn't control anything.
