Good to hear, haven't modified the medialaunch program for a very long time. Should be able to use RRPATH with a /plugins.
Printable View
Thanks. I hard coded the path in there, but I figured there was a variable for it. I looked around for a list of RR variables but couldn't find one. Can you point me to something like that?
Sent from my SAMSUNG-SGH-I897 using Tapatalk
$RRPATH worked perfectly. Thanks again. I'm loving this skin, and after diving into RR I'm liking it a lot more than CF. Although still installed on my carpc, CF has been replaced with RR+Reborn plus a few necessary plugins (wifi.net, bluetooth.net).
RR can be an addiction, you can really customize it to look exactly like you want.
I noticed that if the artist/album/etc has special characters, they don't seem to render correctly in the scrolling display. For example, Röyksopp ends up looking like Korean or some other Asian font. Is this because I'm missing some font?
Auto startup - I'm looking for the way to auto start say Radio or Music so that sound is there at startup.
Currently at startup I have to select Radio then press the Vol + key to get sound.
Similar with Music press play if a song is listed.
I've tried auto load HDRadio.
Got to be an easy way to do this.
Using WINAMP on winxp and win7
Thanks for your reply Dartman_71
Yes we are on the same page.
The resume mode set to "select always" does resolve the Music startup, that is, if music is playing, shutdown and restart music plays without touching any buttons.
Does not resolve the HDRadio, have HDRadio working shutdown and restart, I have to touch VOL+ to get sound from HDRadio.
I have read about a parameter HDRADIOVOLUME which I think is the startup Volume for HDradio and is set at about 75 by default. Does this need to be set in RR.ini in the Radio section.
Very nice skin, I have left CF and tried some RR skins, this one so far meets my requirements.
Excellent work guys great skin.
vol+ isnt a HDRadio command, its for master volume control of the windows mixer
if your playing hd radio, exit rr, and restart rr, what happens... if resumemusic=2, hd radio should be playing...
and i bet it is, and if u cant hear it.. could be nothing related to hdradio... could be something is playing with your volume...
use CARWINGS as test!
