I now have the HDRadio and
Music starting correctly at RR startup, basically removed winamp 2.95 and reinstalled winamp 5.61, plus reinstalled audio drivers from
PCI level upwards.
Only challenge I have now is that the HDRadio start Vol is much higher than the Music. Can I use the HDRadioVolumve setting to get over this, if so what configuration file
should this setting be placed into.
Audio card is on board Realtec, I'm using Green and Blue for front and rear speakers and Pink as the HDRadion input.
In RRconfig I've found I have to set Microphone as the mutting line for HDRadio exit.
If the mutting line is set to disabled and microphone is not muted, there is no
sound at HDRadio starup.
