This for this new update and for your work :-)
Thanks Dartman!!!
Sent from my ADR6300 using Tapatalk
2000 Audio A4 Avant
CARPC --- 95% Complete / -50% WAF (wife acceptance factor)
- Intel D525
- Xonar DS
- Mo-Co-So Case
- Xenarc 706TSA
- Directed HDRadio
- RideRunner w/ Modified Reborn Skin
- Winamp
- ASIO 2.1
- Console
- Windows 7
Greeeat! I will download and try this skin..![]()
I just started with a fresh install of RR, MobilePhone and Reborn. Reborn is saying that it cannot find mobilephone.ini and is closing. What do I need to change in Reborn to make it find the ini? I know .net installed fine since it shows up in carwings.
Message what you get is not from Reborn, skins not usually send messages. I haven't used MobilePhone plugin in year but your issue sounds like MobilePhone installer's profile/legacy mode issue. You should post MobilePhone thread to get better answer.
Thanks, I'll check that out![]()
I have a small issue with rrearth. It is embedded and working fine but it does not take up the whole width of the screen, there is a space of maybe 200px on the right. Is this normal? If not is there a setting somewhere I can change?
I am using earth 6.0 and my screen resolution is 1024x768
any help would be appreciated. Cheers
Good day, I wish to ask an "update" information. I have a RR working well (updated 03/11) and a Reborn skin also updated in 03/11. If I wish to update RR and Reborn, what I have to do for update without loose any setting in skin and RR?
MAny Thanks
GIuliano
