Page 36 of 57 FirstFirst ... 262728293031323334353637383940414243444546 ... LastLast
Results 351 to 360 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #351
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by diverdeep View Post
    Good day, I wish to ask an "update" information. I have a RR working well (updated 03/11) and a Reborn skin also updated in 03/11. If I wish to update RR and Reborn, what I have to do for update without loose any setting in skin and RR?
    MAny Thanks
    GIuliano
    Good day to you too... when you update RR your settings stay as they were. When you update Reborn you can copy to over old files... but i recommend clean install. There's not so much settings what you need to change, mostly menu buttons. If you have made your own stuff to Reborn, new screens or anything else, backup old version before update.
  2. #352
    Newbie diverdeep's Avatar
    Sep 2010
    Quote Originally Posted by Dartman_71 View Post
    ok, many thanks fo help!
    Giuliano
  3. #353
    Aug 2010
    I never tried with 1024x768 resolution but Earth should stretch to embed area in screen without problems. Even if you scale Reborn skin from 800x600 to 1024x768, Earth should stretch fine.
    Run Earth alone and close all sidebars etc. and try again with Reborn.
    Thanks mate that did the trick, I should have thought to do that really.
  4. #354
    Low Bitrate Paul Murray's Avatar
    Jun 2011
    CINTI OH USA
    This skin is my fave! its just not as easy to config. as DFX(or is it?) I have only been goofing on the whole Carputer thing for 3 weeks, so I am a noob big time,but I do like to look and feel of this skin Very nice!
  5. #355
    Aug 2010
    I have been playing around with the Vehicle Maintenance plugin and realised that it didn't track mileage unless I set a port for the gps in rr.ini.
    Problem is once I set that port the maintenance plugin tracked changes but my Garmin Mobile PC no longer does. It keeps asking me to set the button, I have checked skin ini etc to make sure all values were as they should be to no avail.
    Can anyone point me in the right direction please?
    BTW I use GPSGate to share the gps between RREARTH and GMPC and set rr ini to use a separate port.
    EDIT: SORRY, It was DOT NET that had played up on my PC. It's working now but I had to change the overlay return code from CLOSE to EXIT.
    EDIT: Of course anyone who would like my Graphics and Skin files is more than welcome, just send me PM
  6. #356
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Are you using a gps splitter like xport?
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  7. #357
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by JustAnotherDude View Post
    i think he already answered that
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  8. #358
    Jun 2010
    Tromsų, Norway
    Arrow Reborn problems
    Hi!
    When I try to use Reborn skin, there isn't any text in the menus, and Close, Night and Config buttons does not work. I am new to RideRunner too, so there might be a configuration problem
    Using Windows XP 32bits Norwegian, latest RideRunner Release, and Reborn v1.09 installer.
    Do i have to install plugins to get the skin working? Anyway, any tips and hints are welcome
    Screenshot:
  9. #359
    Feb 2009
    Finland
    Kent_AudiA4 please download new version 1.11 from first post. Installer fixed to recognize profile/legacy mode. I'm not sure is't related to your issue but now installer works.
    Please report if you still have same issue, we need to poke little more.
    There's not much in new version and i only release this update because installer wasn't working correctly... but you may like the gauges
    Happpyg made original gauges so credits to him. I just tweak apperance little bit and after help from guru, now altitude gauge works with both Imperial and Metric units.
    Enjoy and all feedback is welcome as always.
  10. #360
    Jun 2010
    Tromsų, Norway
    I've uninstalled Reborn and Riderunner, and deleted all files related to it, and installed everything again, and Reborn worked like a charm..
    What gauges?
