Page 37 of 52 FirstFirst ... 272829303132333435363738394041424344454647 ... LastLast
Results 361 to 370 of 514
Like Tree2Likes
Thread: Reborn (Updated 5/17/12)
  1. #361
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by Kent_AudiA4 View Post
    I've uninstalled Reborn and Riderunner, and deleted all files related to it, and installed everything again, and Reborn worked like a charm..
    What gauges?
    Glad to hear that Reborn works like a charm and problem is solved.
    Click the GPS/satellite indicator in the menu to launch gauges. Of course you need GPS receiver and set com port in RR Config to get the gauges to work.
  2. #362
    Jun 2010
    Tromsų, Norway
    Nice gauges But i cant figure out what is wrong in my config, I use Xport, and I have configged my ports right, i think, in Sygic, the GPS works all the time, but with Gauges, GPS comes and goes...
    I'll figure it out
    Nice skin, it's easy to use and gives the OEM look and feel..
    Click here for a YouTube video with my carpc install
  3. #363
    Aug 2008
    hello,
    using your (nice and clean) skin after having temporarily switched to riderunner from CF (RR seems to be more "my" frontend of choice) i have a feature request:
    you are using this "iList"-Feature... and i've found this thread: http://www.mp3car.com/road-runner/14...ts-please.html
    There is told, that it is possible to add dividers between the entries in the list.
    So... how to add dividers and a litte bit more space in each entry to make the usability better?
    images don't have to be shown as they are only eyecandy (would be nice though )
  4. #364
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    as stated in that thread as well its not a RR feature that can be used as far as i know it has not been attemped ,,,, the scr cap you see is a Flash version ,,, not a rr version ,,,,Dartman may be able to make a sel.bmp with divider lines on it but for the extra text its still a no go at the moment
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  5. #365
    Aug 2008
    i know the thing with the extra text ... but i mean more space in each entry without extra-text ... that the touch-area is larger and it looks little bit cleaner. so can i adjust ilist in height?
  6. #366
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you can open the skin file and up the font size that will give you bigger touch area per line depending on what list the lines would start with
    S or or CL lijnes towards the end of the line is the font type and size
    /, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S01,301,113,457,350,#color#,255,255,255,255,255,25 5,#color#,TRUE,20,"Lucida Sans Unicode
  7. #367
    Aug 2008
    so no chance without enlarging the font-size? font-size is ok but more space would be nice?
  8. #368
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    another way is to make another scr with large list area ,,, this is easy to do
    i think the external_gps.skin might suit your needs (From memory),,,
    copy & paste that skin file rename to example Large_list.skin
    copy & paste the list line from your browser to the new skin file
    save open skin editor ,, to the reborn skin goto large_list and make the list area the size you want ,,, but remember to up the font size to your pleaaseing ,, if i get time today i could make a file for you
  9. #369
    Jun 2011
    EDIT-Reinstalled that works.
    Another question though, As you said in a previous post about gauges? You said click GPS and it brings up gauges, I do so and it just brings a black screen up with the track skip/back/play/stop and power icon on the bottom of the page. I have the GPS com port set in RR config, But i dont know if i have to set anything else on there?
    The gps usb to serial driver is installed on the pc already.
  10. #370
    Feb 2009
    Finland
    Quote Originally Posted by nitrodude View Post
    I said Click the GPS/satellite indicator.
