Page 39 of 57 FirstFirst ... 293031323334353637383940414243444546474849 ... LastLast
Results 381 to 390 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #381
    Aug 2008
    Great news
    Looking forward to the new release...
    Another question: Is it hard work to make a non-volume-control version? I use external soundcontrol and don't use the volume-management of riderunner... For example in GPS-windows there could be more space for the volume-field that could be changed to the songtitle ...
    And also GPS: Sygic fits perfect but doesn't stay on top clicking for example next-button the sygic-window disappears
    I guess a general RR-problem but any clue why this happens? configuration?
  2. #382
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by skeal View Post
    Great news
    Songtitle in Sygic and other navi screens is already done... will be in next update.
    When you press RR buttons, vol, next etc. Sygic disappears momentarily and I can't help with that, RR takes focus and embed app disapears.
    I use Sony RM-X4S remote for most funtions so I don't need to touch screen much, so I don't suffer Sygic disappearing heh.
  3. #383
    Jan 2011
    I can't wait for next Reborn update with what I read here.
    Only one request, is it possible to add support for the DFXVoice plugin for us win7 users?
  4. #384
    Aug 2008
    With the focus-thing in GPS: Does it work if you doesn't use the background image? So only the bar at the bottom? Then it should stay visible, doesn't it?
  5. #385
    Feb 2009
    Finland
    Removing background doesn't help because Reborn doesn't use replaceable background, skin itself is the background.
    Clipping is what you could try, clipping is kind of cutting hole to skin so you see through. Downside with clipping is that you going to see your desktop until Sygic load, of cource it depends how fast pc you have.
    Open Sygic.skin with notepad and find this line, which determines embed application area.
    A01,0,0,800,512,000,000,000
    Add this line below of A01, which clip that area.
    C01,0,0,800,512
  6. #386
    Aug 2008
    yes this was what i mean ... this cutting a hole
    so only the lower (and next release the top bar) is visible... i don't care of a few seconds with seeing background. after first load and standby sygic is visible then...
    thank you very much for this information
  7. #387
    Aug 2006
    Hong Kong
    Hi, Can I change the another font for the Track Name(Music Related text) because I use Traditional Chinese, it has a problem to show unless I change the height in each display Line.
    Moreover, do the playlist (S04 in audio_player.skin) support SCROLL-LEFT feature? how to set it? Thanks!
  8. #388
    Feb 2009
    Finland
    Quote Originally Posted by WolfSkin View Post
    Of course you can change font if you like.
    Playlist does not support commands like SCROLL-LEFT. Playlist scroll selected item automatic if item does not fit to list.
  9. #389
    Aug 2006
    Hong Kong
    Quote Originally Posted by Dartman_71 View Post
    How to change? I read the Object Parameters L01 in Audio_Player by Skin Editor, the font-name is call "SCROLL-CENTER"...
    Does this skin support plugins/skin files addons? Unlike Carwings_Dynamic_Lite skin, I have no idea how to add the skin into menu for choosing.
    Thanks!
  10. #390
    Feb 2009
    Finland
    Thanks!
    Edit Audio_Player.skin with notepad, Font color is done little differently and it confuse Skin Editor. Change font Ericsson GA628 to what is best for you.
    L01,133,27,647,29,#COLOR#,28,"Ericsson GA628","TRACKNUMBER||= - ||TAGTITLE||= - ||TAGARTIST||= - ||TAGALBUM>>PLAYLIST","SCROLL-CENTER"
    All supported plugins, plus other useful info are in readme file. Unfortunately, no one will read them. You can find readme file from Reborn\help folder.
