Thanks, you are of great help!
Anyway, my laptop doesn't work with XP. I will not explain why, my OS is just not negotiable.
BTW, I'm using the 2008 december version of ROADrunner, not RIDErunner. This is also not negotiable.
To mcfly, Installer try to find where you have install RideRunner otherwise it install C:\program files\riderunner\skins folder. You can manually copy skin to skins folder.
Most of your prob's causing old RoadRunner, no support for Win7 and probably it doesn't recognise commands which skin use.
There is no such reason why you can't update to latest RideRunner, even XP can't help you.
Thanks. I'll see if RIde helps.
Speaking of reasons not to upgrade to RIDE..., is the update-nag-screen still there? that's one reason.
Nag screen can now be de-activated look here
Ok, thank you for your replies. It indeed seems to work now, with RIDE.
Will try to remove the nag screen, that's good news, carputer1!
Pierrot, je crois que mon Anglais est assez bon, que les gens m'entendent. Tu peut essayer le traducteur de google ici: http://www.google.com/translate_t Malhereusement ma Francaise est... comment tu vois.
I just installed this skin and it is amazing!! Great work!! I have had BMV2 since day one because I managed to add a Mercedes logo that looked OK, but you even have that built in!
Can someone tell me, what exactly makes mobilephone.net start and connect at RR startup? Menu.skin doesn't have x,mobilephone
