Page 41 of 57 FirstFirst ... 313233343536373839404142434445464748495051 ... LastLast
Results 401 to 410 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #401
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    and...
    Quote Originally Posted by WolfSkin View Post
    In buttonlist.txt
    I changed the command from "ZEITRONIX" TO "ZDL" because I don't want to confuse what is command and what is label, is it must same?
    Command and what is in label does NOT have to be same BUT command have to be same what is in ExecTBL...
    ZEITRONIX||ZEITRONIX
    "ZEITRONIX","LOAD;ZEITRONIX.skin;;C:\Program Files\Zeitronix\Zeitronix Data Logger v3.1.4\zdl.exe;Zeitronix Data Logger"
    If you want to change command to ZDL, Change both.
    Also if you change command or label in buttonlist.txt, you need to select menu button again.
  2. #402
    Aug 2006
    Hong Kong
    Quote Originally Posted by Enforcer View Post
    It's originally based off this skin
    http://www.mp3car.com/rr-released-sk...e-bmw-e36.html
    And the original PSDs are available in the first post of that thread.
    PSDs are normally edited in photoshop but I think you can also use some other alternatives like GIMP.
    Thank you. I try it.
  3. #403
    Aug 2006
    Hong Kong
    Quote Originally Posted by Dartman_71 View Post
    and...
    Yes, I got it. Thank you very much for your help.
  4. #404
    Aug 2006
    Hong Kong
    Hi Dartman_71,
    I try to use the GIMP to create a skin and what to simulate your button and frame style, I try many effect but still not success, do you use GIMP to create the button and frame? Can you teach me how to do?
  5. #405
    Feb 2009
    Finland
    I use Adobe Photoshop and I don't know anything about GIMP.
  6. #406
    Aug 2006
    Hong Kong
    Hi Dartman_71,
    Just let you know that the command code of "Copy to Video" and "Copy to Skins" in Mediacopy.skin is contrary.
  7. #407
    Feb 2009
    Finland
    Oops, good catch... thank's.
  8. #408
    Jan 2010
    Dartman, just want to say thanks for the best RR skin I've tried. I have more work to do on it, and am dismayed that my phone isn't going to work through the PC, but this skin works for me most of the time for HD radio, music, and Garmin GPS.
    Just wanted to let you know we are out here supporting you guys!
  9. #409
    Feb 2009
    Finland
    Thank's flylear45, it's good to hear someone using this skin and even likes from it.
    Small update 1.12 in first post, hopefully it makes Reborn even better.
    Enjoy.
  10. #410
    Oct 2006
    I went to do a reinstall of RR as well as this skin today, and now the text of the song title from the top doesn't want to fit. Instead half of it stays hidden behind the skin. What could be causing this? I tried a search on the forums but didn't see much.
    Thanks so much for the help! Of every skin out there Reborn is by far the most appealing in my opinion! I can't express my thanks for all the work you have put into it!
