Page 44 of 51 FirstFirst ... 343536373839404142434445464748495051 LastLast
Results 431 to 440 of 508
Like Tree2Likes
Thread: Reborn (Updated 5/17/12)
  1. #431
    Nov 2009
    AU
    Hello carputer1,
    Thank you for your help.
    I tried to change it and frankly speaking nothing happened. There is no image and there is no swf file.
    Also, I have tried to use skin editor and there is actually an option to insert a swf into the skin. However, I am not sure if there are restrictions there.
    all in all, it does not work for me.
    Did any one to implement swf file into any skin? It would be greatly appreciated if you could provide some feedback or describe your successful steps.
    Cheers.
    BTW. Am I right that if I delete one of the file I will get two sets of menu, instead of three?
  2. #432
    Nov 2009
    AU
    Sorry,
    I must have confused with another thread where they explain how to use USB radio. That is absolutely gray area for me.
  3. #433
    Registered User
    May 2008
    Problem with FM Radio
    Hi,
    I have just moved from CF to RR. After lookign at a whole bunch of skins I have settled on Reborn as it does almost everything I want without being too busy.
    I however have two small issue which I am unsure of how to correct.
    1. I cannot get the preset buttons on the radio skin to work
    2. When I resume from hibernate the radio reset to another station however if I restart it remembers the station I was on. I have to change to another station and back again to get it to work.
    Otherwise, thanks for an awesome skin.
    Any pointers would be greatly appreciate
    Cheers,
    Wayne
  4. #434
    MySQL Error
    Oct 2004
    waynePnr, you might want to mention more info...
    rr version
    what kind of radio
    things like that
    in reborn, presets (buttons 1 -8) are press and hold
    and the presets are stored in the FMPresets folder
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #435
    Registered User
    May 2008
    Thanks Mitchjs, good point
    I am running the last version of rr (Feb) and I am using the ADStech RDX-155 FM USB radio.
    I have tried the presss and hold as that seemed logical but it doesnt seem to store the channel. Will look a little deeper to see if there is a permissions issue or somethign similar.
    Cheers,
    Wayne
  6. #436
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by WaynePnR View Post
    Cheers,
    Wayne
    This is just a wild guess, do you have "FMPresets" folder in RR root or "C:\Users\username\Documents\RideRunner\Config " folder? Location depends are you in profile or legacy mode.
  7. #437
    Registered User
    May 2008
    Thanks Dartman_71, that solved the problem with the presets.
    The radio still does not remember the station it was on when it comes out of hibernation, any ideas on how to correct this?
    Thanks,
    Wayne
  8. #438
    Feb 2009
    Finland
    Thanks,
    Wayne
    Sounds like RR installer doesn't make FMPresets folder, I don't know should it do, that's Mitch's job to know.
    I remember vaguely that I had same problem when I start to mess with RR a few years ago... but my memory doesn't serve me very good anymore hehe.
    I can't help you with hibernation issue. I have Directed HD radio in car and Silabs USB in home, both resume in last station when wake up from hibernate. I don't know if there some difference between Silabs USB and ADStech RDX-155 FM USB which may cause hibenate issue.
  9. #439
    Dec 2010
    hallo
    1- i have installed garmin mobile pc and configured it in config menu and exectbl.ini, sed when i click on the gps button it don't play automatically.. why ?
    2- how can i see DVB on this skin? you say: "DVB skin on the right side is a hidden button which opens and hide DVB buttons." but i don't see this button.. where is it ?
  10. #440
    Feb 2009
    Finland
    Quote Originally Posted by maradona10 View Post
    hallo
    1- Double check Garmin path in exectbl.ini. If path to Que.exe is correct and you have select Garmin in config menu, all should be fine.
    2- You need to have DVB Viewer software installed and configured with you DVB device. Also you need DVB Viewer plugin.
    Hidden button is invisible area on the right side of screen, when you touch it buttons show.
