Page 45 of 51 FirstFirst ... 3536373839404142434445464748495051 LastLast
Results 441 to 450 of 508
Like Tree2Likes
Thread: Reborn (Updated 5/17/12)
  1. #441
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Updated version 1.13 released, download link is in first post as usual.
    Would be nice to hear, does someone using this skin anymore?
  2. #442
    Feb 2011
    Netherlands
    Yep I am still using your reborn skin.
    It is my favorit skin ,nice and simple no fancy colors or logo,s
    Keep up the good work and thank you for that.
    Is there a reborn skin for the rss reader available?
    And by the way I used the update 1.13 ,is the buttonlist.text not used anymore ?
    How can i at rssreader to the list again?
    I can add rssreader to the menu.lst and the button works but the text rssreader isnt showing on the button itself.
    Just a empty button .
    What i used is rssreader ="rssreader"
    and rssreader="rssreader||
    Thanks again from the netherlands
    Edit:P.S. the draw and the pdc button are using the phone icon how to change that?
    Edit 2:Allready found it :change phone.png to draw.png in the menu.lst .
  3. #443
    Feb 2009
    Finland
    Quote Originally Posted by zolis View Post
    From version 1.13 onwards Reborn use new "Dynamic Menus" and when all plugins are updated to support it, user not need to edit anything anymore.
    Until Sonic's update RRRSSReader plugin to support dynamic menus, you could edit Menu.lst yourself. Just add to Menu.lst:
    Cool, you found bug, thank's. I'll fix DRAW and PDC in Menu.lst to next update.
    Edit: There's no skin in Reborn for the rss reader at this moment.
  4. #444
    Dec 2010
    @dartman
    where is the menu ?
    where are the button ?
    i have installed rssreader and modified menu.lst..
  5. #445
    Feb 2009
    Finland
    Quote Originally Posted by maradona10 View Post
    @dartman
    where is the menu ?
    Even if you modified menu.lst there's no skin for rssreader so you not get it work, by editing menu.lst you get rssreader option to button list.
    Like when you press and hold menu button, menu pop up where is button options.
    Edit: Have you press and hold buttons?
  6. #446
    Dec 2010
    i don't understand..
    can you post the file menu.lst modified ?
    thank you
  7. #447
    Feb 2009
    Finland
    thank you
    Me neither...
    Try this.
    Attached Files Attached Files
  8. #448
    Feb 2011
    Netherlands
    Well after the update mine menu buttons were empty as well .
    So I had to select a new function for all the buttons.
    And for the rss reader i made my own skin for it ,not as nice as the real reborn skin of course
  9. #449
    Newbie bebopblues's Avatar
    May 2009
    I'm using 1280x720 resolution. The song name and playlist name is getting horizontally cut off in the music browser, perhaps the font size is too big. How do I fix this?
  10. #450
    Feb 2009
    Finland
    Quote Originally Posted by bebopblues View Post
    Skin is made for 800x600 resolution and if you stretch skin RR have tendency do that. Only way to fix that is manually edit font size in .skin files... and there is lots editing.
    You should also check Windows font size, if you have set Windows to use large fonts then this happend too.
