lol found itthanks mate
using PC Navigator 9 but no clue how to add it as button in menu![]()
You didn't tell what navigator you use... but after you locate Reborn folder, there is exectbl.ini file and when you open with notepad you see there is section "program paths" where is navigation program paths, you need to edit path to match yours.
Then run RR and in Reborn skin click config button, then gps button and select navigation from list.
or... if you have set your navigation settings in RR config, then you can also select "custom" from Reborn gps list.
If you have installed RR to legacy mode then Reborn folder is in RideRunner\Skins folder
or...
If you have installed in profile mode then Reborn folder is in C:\Users\Username\Documents\RideRunner\Skins folder
Hmm.. Navigator 9
Select custom from Reborn config gps list and try something like this in RR config.
Settings are for PC Navigator 12 free but worth of trying.
thx mate, it worked with carwings with no problemused navigator 9 for testing purpose only as couldn't make my nokia bt gps working with garmin
wow, managed to add new button messing up with menu.lst and menu.ini![]()
and have working navi in Reborn
this can't be true ...cant believe... it was so easy
quick extra question: can't change from km/h back to date, is there any trick to do that? tried tips from first page and only this one won't work mean switch back to original state
tried this but date won't come back...
btw when pressing it, selection menu popped out with select button function: tv, phone etc.... tried again but nothing. any idea how I've got it, cheers
Did you PRESS and HOLD actual km/h text in upper display? if you pressing date-km/h label and button function pop up show up, then you have something seriously wrong there.
I don't know what files you have change or edit but event what you describe should not happen.
Button function pop up show up only when you press and hold some one of the six buttons in menu one, two or three.
Yep did as you said but no change ... About button menu, probably pressed two buttons in the same time
Sent from my iPhone
Just FYI, I can't long press with my touchscreen because it activates the right click. Either disable long press right click or use a mouse.
