Page 52 of 57 FirstFirst ... 242434445464748495051525354555657 LastLast
Results 511 to 520 of 564
Like Tree3Likes
Thread: Reborn (Updated 5/17/12)
  1. #511
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    For the click sound if you are using touchkit as in your system tray, click on that and there is a setting for click sound in that. As well as in windows sounds as you know and have already unchecked. Just a thought SNO
  2. #512
    Jan 2010
    Touchkit has a "beep on touch" option but the "click" noise is still there.
    Sent from my GT-I9100M using Tapatalk 2
  3. #513
    Sep 2012
    Germany - Munich
    edit the exectbl.ini in skinpath, not RRpath
  4. #514
    Jan 2010
    That worked. Thanks.
    I had to remove the lines of text rather than placing a "/" in front of the line to have it work.
  5. #515
    Jan 2006
    Dublin, Ireland
    Hi all
    I am using MS Paint to change the colour of white lines to BMW Amber (to match the in car dash display and aircon etc). Where would I find the setting to change the colour of the Play button ("|>") below MenuItem 6 ?
  6. #516
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    I have expanded the reborn skin for the obdxr plugin , I believe I did a fair job but in the settings skins I don't see the text , anyone know where I went wrong?
    I will post the skin files here, but it is by no means complete , small items need to be addressed.
    http://www.mp3car.com/attachment.php...1&d=1376643921
    Attached Files Attached Files
    View my worklog here
  7. #517
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This is my Reborn version :-)
    This version is a Dynamic menu version (Please do a backup of your files)
    http://www.mp3car.com/vbulletin/atta...compatible.zip
    A new version solve some issue !
    http://www.mp3car.com/vbulletin/atta....0.4-setup.zip
  8. #518
    Aug 2010
    sweet, thanks
  9. #519
    Aug 2010
    question about an external app.
    I am trying to make a window appear inside the external gps skin , I have made a button in menu.lst, I have created a programpath in exctbl.ini , when I press the menu button the app starts but wont fit into the externalgps skin , it will go into the background.
    How do I solve this?
    Do I have to change some settings in the skin file?
  10. #520
    Sep 2012
    Germany - Munich
    check application name
    btw: if you want get help, tell your code.
