Page 7 of 21 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 203
Thread: eLite | Wings (eLite Wings 2 update)
  1. #61
    Jun 2007
    St. Louis
    Quote Originally Posted by suavecito View Post
    As long as you set up garmin as stated in post #2 and you set up iguidance using rr config, you can run both.
    awesome. Going to install this one asap then
  2. #62
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Hot slit.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  3. #63
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    The play icon just means that you are in audio mode. You will see the icon change when listening to Xm, Sirius, or HD Radio.
    None of which i have hence the confusion. Thanks for Clarifying. That would be a perfect place for the heading indicators since you usually know already what mode your in.
    I wanted to point a couple things out that i came across.
    * Problem with OSK (may have been mentioned?)
    When clicking the Web button-->OSK it comes up for 5 seconds and then goes away. I don't have an issue with the timer (although 5 seconds is a bit short) but when it goes away it goes back to the main menu screen. This should take you back to the Web screen
    * Problem with MobilePhone.net plugin
    It is looking for "mobilecall.skin" (i think??? may be mobilephonecall.skin) of which does not exist so it throws an error. When this happened was when I recieved an incoming call. I think this skin was just not included.
    Any Ideas?
  4. #64
    Jan 2004
    California
    Also
    * The Bluetooth Indicator doesn't seem to work
    Even when my phone is connected over bluetooth and the mobilephone.net plugin is functioning (making and recieving calls) the indicator never changes from the greyed out state.
  5. #65
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    1. Okay, the osk timer will be changed for 30 seconds.
    2. Yes, I forgot to include the mobilecall.skin. I will added to the next release.
    3. Bluetooth icon is used for PHOCO, but I will to change to .Net Phone instead.
  6. #66
    Jan 2004
    California
    Excellent!
    I really like how you built the skin with different interchangeable graphic peices. It makes it very easy to modify
    Top quality IMHO
  7. #67
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Quote Originally Posted by antimatter View Post
    Excellent!
    I really like how you built the skin with different interchangeable graphic peisces. It makes it very easy to modify
    Top quality IMHO
    This is one of the main reasons why I have not finished with Elite 2 and Elite Streamline.
    Each image has to be placed individually and it takes a really long time, but in the end it makes it easier to modify and update the skin.
  8. #68
    Jan 2004
    California
    I added a radar section to the Weather skin (like lsxvoid) It includes the Current, Temp, and Doppler images from weather.com
    Let me know if you want me to post the files that modified.
  9. #69
    Jan 2004
    California
    I noticed something else
    * The offstate for the online indicator is the greyed out XM logo indicator
    C:\Program Files (x86)\RideRunner\Skins\eLite Wings\Elite\top-indicators\indicator-WEB.png was wrong...
    I just copied over indicator-net and renamed to indicator-web
  10. #70
    Jan 2007
    [QUOTE=nst6563;1378836]
    QUOTE]
    This is the ONLY modification I'd make on the Garmin Screen:
    Not a lot different - but it hides the top of the Garmin screen and a little of the bottom which gives it just a little more screen realestate.
    Can you please tell me how did you do that?
    I want this modification
    Thanks.
  1. eLite Lite 1.6.6 (NEWS UPDATE 9-15-11)
    By suavecito in forum RR Released Skins
    Last Post: 10-29-2013, 11:03 AM
  2. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  3. mplayer and videos
    By superman279 in forum LinuxICE
    Last Post: 05-13-2010, 11:57 PM
  4. Replies: 41
    Last Post: 01-11-2009, 03:46 PM
  5. Centrafuse 1.14 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-01-2007, 11:34 AM
