Can I get a little help with AVS?
When I press visualization button in RR nothing happens.
What do I need to configure to make it work?
Thanks.
IMHO this is the best looking skin ever. Big fan of the LSXvoid and carwings, but this one beats them all on looks. I hope it will get the support and addons LSXvoid had for a while. In due time, of course. Now if it was incorporated into RR, that would give it a big boost (no. of addons and for RR too).
Apart from RRMedia, I'd love to see GEarth/Traffic and a white(ish) background/black(ish) fonts, that is a high contrast theme for those really sunny CA days...
Can't wait. Great job, Suavecito.
Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
Skin: MetroSex on the Beach preview
07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
Thanks.
I am having the same problem and the AVS option is checked in rrconfig. Is there anything else I can try?
I saw a few pages back that you cannot load playlists from the skin which is another problem I am having. I see Suavecito is working on a fix for the next release but is there anything I can do in the meantime to make it work?
This is a great skin and it will definitely be my new default, especially if RRMedia gets added in the future. Great job!
Thanks,
Avs Problem:
In the RR Config
-> Music
--> Page 2
----> Click Avs Window
-> INI Extras
--> Paste the following
-> SaveCode:transparentvisu=true opacityvisu=40
Playlist Problem:
-> Go to the Elite Wings Folder
-> Open audio_loadplaylist.skin in Notepad
-> SaveCode:SD,0,03,37,35,"$playlistpath$","*.m3u",
Thanks for your quick response, I appreciate it.
I went into INI Extras and typed what you suggested, saved and restarted RR. However, when I clicked on visualization nothing happened. I went back into rrconfig and checked INI Extras and noticed the words I just typed were no longer there. I tried typing them again and they are there when I save and exit but do not appear to be actually saving. Do I need to enable the INI Extras option somehow?
***UPDATE*** I re-installed Ride Runner and it fixed my problem.
Originally Posted by suavecito
I did not see audio_loadplaylist.skin, all I have is audio_currentplaylist.skin and audio_loadlist.skin. I assume you meant audio_loadlist.skin so I made the changes and my playlists now show up. The problem is none of my songs play when I click on the list, instead they keep switching from song to song like the link isn't valid. However, if I exit out of RR and manually click on the same playlist it loads up in winamp and plays just fine.
This part doesn't seem the most intuitive - but when I click Load Playlist it brings up a list of my playlists which is fine. Then when I click Open Playlist it just browses to the songs instead of playing anything right away. I then need to double click on a song for it to activate. However, instead of playing the song it just cycles through all my songs without actually playing anything as I mentioned above.
I uninstalled winamp and reloaded it again yet the same problems persist. Anymore ideas?
***UPDATE*** It turns out Elite Wings will not play previously created playlists, you have to create playlists within the skin itself. This is a little strange but whatever, it works now.
I would like to make a suggestion
Problem:
GPS and other embedded applications (rrearth, web, etc) don't stay running after clicking the back button (bottom, left most button)
Solution:
Assign two funtions to the button. Press once enters goes back to the prior screen. Press and hold for 2-3 seconds it closes the application and goes to the prior screen.
What do you think?
Very nice - thanks for sharing.![]()
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
So I have been playing with this skin in the car for the past few days and I like it very much. The only issue I have had is its visibility in the daytime. So I have modified it for a daylight version. It is now the best skin out there. Thanks for the hard work. After going through the code to modify I saw some creative solutions to different problems. I am very impressed.
Oh, post some pics, maybe Suavecito will incorporate that as a theme? Or maybe you could PM it to me?
Daylight enhanced skins is all that I care for these days, and the more the merrier.
