I would like this also. I really like the Garmin GPS software. I guess I have to find something else to switch to now that Garmin doesn't support it anylonger, but I'm holding out with Garmin as long as I can.
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Thanks a lot and appreciated. I never really used the visualizations but figured why not get the most out of my new build. Thanks again for the file.
No I did not. I have never used the net radio other than one time when DFX4 was first released. This is my first foray into it. The pre designated stations do nothing and there are none listed. How do I set these up? Is it just an .ini I have to edit? I remember the pre designated sations working before on previous installs but none of it is functioning at the moment.Dougw133, If you overwritten your "InternetRadio" zip with mine from page #961 then you will only get my added stations, Sorry, I should have been more clear on this.
I re-upped the zip with all the original urls in it to so you can now overwrite with no probs
Dougw133, Go into DFX5 skin folder and there should be your "InternetRadio folder", open "StationList.ini" in notepad. Are your stations listed? If not, take my zip posted on #961 and delete the one in DFX5 folder, and put mine in it's place. Don't tap or click the...."update station list from the internet" button. This will delete the list. This has been addressed, and this bug might be fixed in up coming DFX5. Good Luck.
Thanks I'll give it a shot. Can I sue any URL radio station or do they have to be shoutcast? When installing winamp I did not include any shoutcast.
Dougw133, now to add your own stations (urls).
1. Go into your "StationsList,ini" using notepad.
2. Pick a genre, you want to put you url under, ie
[Rock], [Classic Rock], [Metal] .etc
3. Now in the list of the genre you have chosen, add @ bottom of list, with next name and link number... ie
Name(type next number next in order)=(the name of the station)
Link(type next number next in order, same as name)=(type your station url)
ie,
Name1=Rockin Radio
Link1=http://yp.shoutcast.com/sbin/tunein-station.pls?id=629215
Name2=96 Rock
Link2=http://yp.shoutcast.com/sbin/tunein-station.pls?id=581651
Name3=Rock Radio
Link3=http://scfire-ntc-aa04.stream.aol.com:80/stream/1043
Namex=xxxxxxxxx
Linkx=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Yes, you can add non shoutcast, but don't tap/click the update button or they will vanish, POOFFF! all gone.
I hope this helps.![]()
Thanks again. Pretty much what I tried to do yet nothing works. Pressing the any of the stations does nothing at al. No audio, no nothing. I tried your internet radio from post 961 ans still nothing. When I hold a button and Select "Choose Preset" there is nothing listed what so ever. I'm baffled.
On a side note tried to change a button today. This is DFX 5.1 patched latest RR with hotfix.
That's strange, maybe john or blue can chime in on this one.
Good Luck bud.
so win7 anyone wanna help me with that security screen problem? a hint or something
