John, now you need to update your avatar to 5.1 :)
Printable View
Just bought and installed the donate version of the skin to do away with the "not registered" splash screen. I still get it even after I install the update. Any ideas?
I have seen the issue with Google Traffic identified 2 or 3 times in the thread with no solution. I too am having the same problem. The problem is when clicking the "G Traffic" button, I receive an AutoIt Error which states: "Line -1: Error: Variable used without being declared."
Does anyone know why I am receiving this error and what to do about it?
We will go thur these last posted issues and get out the updates sometime by the end of this weekend but will shoot for Friday.. So that we can move on to 5.x+
Blue, great to hear........thanks bud. :)
Anybody else finding that the bottom buttons for increasing, decreasing and muting volume are not working after the patch is installed? I have done a total rebuild of my system from OS up, so it could be related to something else. I just thought I would see if anyone else is experiencing it.
I'm not sure what you mean by that. Blue. Everything appears normal in terms of volume settings. DFX shows volume at 50% on menu and nothing I do changes that. The volume up, volume down and mute buttons don't do anything. All the other buttons on the bottom of the screen work. I can't figure out what the problem is.
I know.... Somehow you have the gps volume on and rr is overriding the vol cmds. Check the speedatt setting in the skin.ini.
Or the volume controls are not mapped correctly for your sound card. I have seen this happen before. DFX controls "MASTER Volume" by default, it may be called different with your sound card / setup.
Delete the debug.txt in the RR folder if there is one there. Then open RR.ini and ensure that debugging is set to "true"
[Debuging]
debugmode=true
Then open and close RR. Now open the debug.txt and look for lines like this:
5/20/2011 2:28:38 PM: PLAYER: Initialization complete
5/20/2011 2:28:38 PM: Master Vol: Master Volume/4
5/20/2011 2:28:38 PM: Master Vol reports number of channels =2
This is where RR reports what it found for your sound card volume, lines, treble, bass ect ect... See if it has any errors for the master volume reported.
