I soooo knew that statment was going to get me in trouble.
No seriously, wasn't planned to take this long but would keep finding little things everytime I thought it was it, then the hours dragged on latter and latter into the night, and at some point just called it a night. So that now leaves tonight, as I now have other things that need my attn.
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
That's OK blue, take all the time ya' need my friend. I couldn't resist......hee!-hee!![]()
My Fiero Build Thread
I am having this issue as wellBut since I've never used it I guess I won't miss it.
I'm trying to get a GPS program to work. I have 3 different versions of Streets and Trips, and i can't get any to function properly. Ever since DFX4 the Streets and Trips button has not worked. The only way I can get Streets and Trips to launch is to either use the GPS button from the music skin, or by going to the Sirius skin, then going to the favorites skin (one with icons) then touching the "next" button. On my DFX4 install, once the app was opened it worked fine.
I'm also still having issues with the buttons in the Streets and Trips skin only working when I "drag" my finger on the button (or mouse) instead of just touching (clicking) the button. Touching = GPS app losing focus and coming back, dragging = proper key presses (can see the menu, i.e. alt-f-s).
The power button on the exit screen would be better on the left instead of the right, as on most car radios, this make sense that it is closer to the driver. Just a suggestion.
I have just purchased a Visteon HD Radio and am waiting for my cable to be made for connection. Since the radio is not connected I cannot check the line in connection switching.
My question is, can I make a simple DFX skin that will check the winamp line in switching while waiting for my set up to arrive? I may also just continue to use this later for an external player input, as I like the EQ availablility with Winamp.
I have the Jaspers Line In Plug In already installed and working in Winamp.
Thanks.
CAR: 2007 G35 Sport Coupe 5AT
HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
Yes, the config was fixed but if you didn't re-dl rr after it was fixed then that my be the reason it's not saving correctly for you
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
I downloaded and reinstalled RR yesterday. This was from the NISU site though. Maybe it is not updated there yet.
Edit: Just uninstalled and reinstalled RR completely. Same not saving issue and descriptions no being able to be read. Etc.
Same version of RRConfig 1.02.22 is still being downloaded with RR as in your RRConfig thread post 607, as of last night 5/24 5:10pm PST.
